Old 08-12-2005, 12:10 PM   #1
gregbr
Senoir Member
gregbr's Avatar
Which posi/limit slip unit??
Which one is better and why......and what should I look for?? This would go in my 67 K10 rear (do the front later) with stock 3.73 gears. It only sees light 4wd usage, too much $$$ to tear it up. I see all kinds of units of different sizes, but don't know what fits.
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 08-13-2005, 07:02 AM   #2
gregbr
Senoir Member
gregbr's Avatar
ttt
Old 08-13-2005, 10:10 AM   #3
Purs
Got Big Block?
Purs's Avatar
Eaton for a Posi. because they are the best. If you can live with the clicking, many people have been happy with Powertrax lockers. Call Randy's Ring and Pinion and they can help you.
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 08-13-2005, 10:16 AM   #4
Jeff M.
Jeff M.'s Avatar
I'm very happy with my Eaton posi. Installation was pretty easy and it works great.
69 C-10 CST Short Fleet, Factory Air, BB427-400 Auto-2400 stall-tilt-cruise-Tach & Vac Gagues, 4/6 drop, power one piece side windows, Eaton posi.
Jeff M. is offline   Reply With Quote
Old 08-13-2005, 12:40 PM   #5
gregbr
Senoir Member
gregbr's Avatar
Eaton posi.....Do I look for one for a 10 bolt axle, or a inch size?? Does it require special tools or knowledge to do yourself? Thanks, Greg
Old 08-13-2005, 06:13 PM   #6
Purs
Got Big Block?
Purs's Avatar
goto http://randysringandpinion.com/ get the 800 number and call them on Monday. Tell them what you have, what you think you want and then let them give you the info to help you make a decision. They were very helpful when I called for info and I didn't even buy anything. Because they were so helpful, I made my purchase through them once I decided what I wanted.
Old 08-13-2005, 09:30 PM   #7
ac102nv
ac102nv's Avatar
I agree with Eaton mentioned above. I know a couple people that have them and they really like them. I have a Powertrax in my 12 bolt. Will NOT buy another and when $$ permit it will be replaced. I kinda like the clicking, what I don't like is I chewed one up in under 5k miles. They replaced it at no cost. But still don't like how it acts. I've had it unlock completely and freewheel. Thankfully didn't blow up the engine when it unlocked, and as the engine was winding down it hit REAL hard when it locked back together. Just my $.02 but I won't buy another for the street. Maybe for your front since it will only be used offroad would be OK.
'72 C10 lwb 454/TH400
ac102nv is offline   Reply With Quote
Old 08-15-2005, 06:08 AM   #8
gregbr
Senoir Member
gregbr's Avatar
Thanks!
Old 08-15-2005, 08:33 AM   #9
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
You should have a 12 bolt rear axle, and a dana 44 front. The thing about the powertrax is it's a drop in locker and uses the existing carrier. The eaton will require pulling the carrier and swapping it with the eaton.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
