08-12-2005, 01:46 PM | #1 |
C20 brake booster on a C10?
I just installed a brake booster on my 71 c10...but I think the booster is from a c20 truck which appears to be bigger....Will the bigger booster damage my brake system?.....Thx
1973 gmc swb |
08-12-2005, 01:56 PM | #2 |
Nope.
You just gave your self a brake upgrade. |
08-12-2005, 06:37 PM | #3 |
its all about the +6 inches
That looks like a 1/2 ton unit to me.
08-12-2005, 08:58 PM | #4 |
I think Longhorn is right, that is a C-10 booster.
Jim |
08-12-2005, 11:25 PM | #5 |
"Trucks with Class"
That looks like a 71-2 dual diaphram 3/4T DB booster, to me. It will work OK, but not with that 1/2T MC. You need to run the correct matching 3/4T MC so the throw/rod will push it in correctly.
08-13-2005, 06:04 AM | #6 |
I stand correctd, and realized why I made the mistake... I'm thinking 70 and older....drum/drum stuff where the 3/4 ton/one ton booster is not as large in diameter and much much deeper as viewed from the front.
08-13-2005, 08:12 PM | #7 |
I looked at the picture and thought the booster was not thick enough but it is a C-20 and as PICKMUP said it needs the right master cylinder.
Here is a pic of what it should look like, (this is on our C-10 and works great). Jim |
