Old 06-27-2002, 05:12 PM   #1
dion
72 Cheyenne
dion's Avatar
Loose Tie Rod
Everything is tight but I can still move it back and forth, Bushings?
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 06-27-2002, 06:06 PM   #2
Alexis
Member since 2000
Alexis's Avatar
tie rod arn't ment to be solid they willl alway have movment. i hope you meaning you can grip the tie rod and make it move toward the front of the car and toward the back fo the car wiht just a simple wrist movement.
Alexis is offline   Reply With Quote
Old 06-27-2002, 06:25 PM   #3
dion
72 Cheyenne
dion's Avatar
Yes, I'm guessing that's normal. I'm still getting a clunk when I turn corners and a huge bam! when I hit pot holes. I just put new shocks in.
Burnout
Idle
1972Cheyenne
1966/67Stouts
Old 06-27-2002, 06:33 PM   #4
bigvinnie
bigvinnie's Avatar
I would be looking at upper and lower control arm bushings for the source of the noise.... best way to check is to be looking at the control arms from underneath while someone bounces the front of the truck up and down....
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 06-27-2002, 06:53 PM   #5
dion
72 Cheyenne
dion's Avatar
Okay we did that, now what should I look for to tell what the problem is? Thanks for the help.
Burnout
Idle
1972Cheyenne
1966/67Stouts
Old 06-27-2002, 07:56 PM   #6
bigvinnie
bigvinnie's Avatar
if the front springs aren't indexed properly into the lower spring pockets you'll get some noises there..... only other things to look for would be worn idler arm. ball joints, motor mounts.....
sometimes you just gotta wait til it gets worse to find the source
72 Stepside Project
Old 06-27-2002, 08:01 PM   #7
jhwkns
Registered Cruiser
jhwkns's Avatar
If the cushions under the radiator support are thin or just plain gone. The radiator support might be hitting the frame.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
