my steering sucks on my 1972 gmc 1/2 ton 4x4.any ideas?if i point it straight it will go right and left. i think the box is bad. is the box the same as the 73-87 box?
I was having a bit of this problem as well. My truck dives to the left (yes oncoming traffic) a little bit. I was hoping it was something like tie rods and didn't really want to hear that my power steering box was going bad.
Sorry no real fixes, only sharing in the pain.
72 Chevy Short Bed Fleet: 350/TH350 - Sold - Now trying to sell the parts that I have left over. _______________________ 2006 VW GTI |
"Ochre Ogre"
You are in luck, they are the same at least until the lines went metric.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
![]() Join Date: May 2004
I believe to use the 73-up ps boxes, you have to notch the bumper brace slightly. They are also variable power assist. Much better from what I understand.
![]() Join Date: Feb 2001
This needs to be over here. These guys know their stuff. Just have a little patience. I would start by checking the frame for cracks and loose joints while someone steers it from side to side. Sounds like you have some worn out stuff or something is loose. Oh and if you are laying under it make sure you trust the one behind the wheel....
Top
Currently Blazerless
You might check your inner axle u-joints, they can freeze up solid from rust and make the steering awful squirely.
Raise the front of the truck up off the ground and with the wheels straight you should be able to spin both tires freely, now turn the wheels to the right and spin them again, then to the left, if there is any binding replace them.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
BlahBlahBlah
i think i read here somewhere that the 4x4 box is different than the 2x4 so if you get a newer box make sure it was off a 4x4. mine was doing the same thing once and it was as simple as a couple of loose bolts holding the box on. sometimes its easy to forget to check the simple stuff first.
