04-14-2002, 07:42 PM | #1 |
Timing Problem
I posted this in the Engine board, and I dont think anyone knew for sure. This I think is a common 350 question. I hope someone can help me. I have a 77' Chevy c-10 350/350 turbo with 4 barrell. I had the timing checked and it was at 4 degrees. The engine sounds like it was running 4 to 500 rpm. It will slowly take off if the brake is released. What should the timing be set too ? And if mine is wrong could this make extra valve noise, and rob it of power ? Its strong now, but I think it isnt getting its total potential. I have a dwell and rpm test machine, but I cannot find the wire to clip the end on to make it work. The truck has electronic ignition. Anyone know what color wire im looking for ? Thanks in advance
04-14-2002, 08:09 PM | #2 |
Old member
The timing depends on if it's a auto, or straight drive? If it's auto it should be around 6 to 8 degree's top dead center, with the vacuum unpluged and something plugging the vacuum leak. If it's a straight drive 5 or 6 should be ok. Hope this helps.
------------------ Andy 71's Are for ever!!! or 67,68,69,70,72 www.geocities.com/chevy71tpi/main.html] www.picturetrail.com/Andy4639]
04-14-2002, 08:12 PM | #3 |
By straight and auto your talking of the transmission ? Its got a turbo 350 tranny.
