08-13-2005, 05:01 PM | #1 |
2 temp sensors? ZZ4 swap
hey guys, its me again. I am getting so close!
sorry to keep bugging you, but I am putting in the zz4 and hit another snag. the old motor had two temp sensors, one on each head. the zz4 only has one. do I need them both?> their is a place threaded on the head, but doesn't fit the old sensor. thanks! |
08-13-2005, 05:19 PM | #2 |
Watch out for your cornhole !
You only need 1 sensor, the one to the guage. I don't know why you had two previously.
The hole in the heads on the ZZ engine will be too small for the trucks original sensor. No one has ever found a proper sensor with the small threads for a 67-72 temp guage. We discussed this at length one time, on here, and never were able to find a good solution. That leaves putting it in the intake manifold as the only option. Does the ZZ intake have an extra 1/2 NPT hole in it to use?
08-13-2005, 10:58 PM | #3 |
the zz4 already had a sensor in it. I bought it used.
plus it has a edelbrock performer RPM intake manifold. so your saying this sensor probably won't work with factory gauge? |
08-13-2005, 11:43 PM | #4 |
I seriously doubt the sensor will work, but if it does, there will be a lot of people interested in knowing what kind it is!
08-13-2005, 11:55 PM | #5 |
huh?
I know there was a member here that had Mike in his name (I know that really helps) that used a Volvo temp sensor for the smaller temp sender hole, and it put the needle right in the middle of the temp gauge at operating temp.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
