What Hump?
Help need your opinion or just two cents
We found a 74 k-10 4x4, gmc, it is pretty much stock, 33" tires, original paint and so on. Here's the problem, the front and rear seals are leaking, 1" diameter drops after 10 minitues of setting. The trans also feels like it takes long time to get it going in reverse, slips so I know a rebuild is around the corner. What would you expect to pay? $1100 straight body no if minimal rust. And what can i expect to pay to have the seals done?
Thanks ahead of time Tom Sorry no pics my camera fried on me.
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
ureckmefixit2@cox.net
I know a few shops here in gilbert. Good guys wont be to much. and I have a family member that has a trany shop too. Matt
That's U RECK ME FIX it 2 74 Chevy Short Bed 355ci Sportsman II 64cc Angle Plug Crower Custom Grind .462in .486ex Dyno Test 422hp @ 5600 And it's got a Holley 3.73 Gears 12 Bolt 3.73 w/Posi 700R4 Going In I'm a Body Man So There! That's why it's not painted |
Overworked and Underlaid
i recall one time in about 2001 or 2002 i spoke to a gm only tranny shop-talked to a guy named alex there-its a family owned business.now this was for a 2WD TH350 with a shift kit it was 400 even out the door and they would install it included in the price and they would tow it too.they were on southern and horne in mesa.i also had a truck one time a 2WD shortbed that when i bought it had a trans in brand new from a shop called transplant located somewhere in phoenix and i called them once about there prices they wanted 325 but you install it.that was one of the best trannies i ever had.you might check into them too.as far as your axles i think most any parts stores should sell complete overhaul kits for axles if your up to the task otherwise im not sure of the cost to get them done at a shop.call around your area and see what a shop charges to do it then factor that into the cost of buying the truck and then go from there.good luck.
I'd rather push a Chevy than drive a Ford The Beast-1978 C10 LWB Red-1978 C10 LWB (Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012 Gone but will never be forgotten-RIP (Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012 Taken from us to soon but you will live on in our hearts-RIP |
