08-13-2005, 07:37 PM | #1 |
Active Member
205 transfer case auto adapter
Looking for adapter for auto. Have '72 blazer. Will trade or sell one for 4-speed. Anyone know what they are worth? Thanks.......Rick
08-13-2005, 11:04 PM | #2 |
Need to know which tranny & transfer your running, since it's a 72 I would guess TH350 to NP 205, figure 8 style with 27 splines.... but then who knows?
NP 205 to Th350 adaptors run anywhere from $75 & up depending on location, and I have seen them as high as $150. |
08-14-2005, 12:35 AM | #3 |
Active Member
It had a 4-speed, I am converting it to a TH350. Will check on NP205 # and splines tomorrow. Thanks.......Rick
08-14-2005, 01:36 AM | #4 |
If it is a TH350 it's 27 splines. What else do you need? An auto trans crossmember, different driveshafts? How about linkages or a single pedal set? Might as well make a shopping list since your here.
08-16-2005, 12:54 PM | #5 |
Active Member
I need the adapter for TH350 27 spline to np205. Don't know if crossmembers are different? They have same mount on bottom of adapter. If you can move existing crossmember, it would be easier to drill new holes. Won't have body on frame when installing driveline. Have linkages and cab for auto. Would sell front tub set up for 4-speed, with adapter. Thanks........Rick
08-17-2005, 07:32 AM | #6 |
Adapter
If the 205 that your using was originaly from a standard the spline count will be 10 spines. The 205's that came behind th350's had 27 spines. The easiest way to do the swap is to find a 205 that was from an auto set-up. You can get an adapter from Advanced Adapters that will allow you the put the 10 spine 205 behind a th350. You may also be able to change out the input shaft on the 205 to a 27 spine shaft.
The cross members are the same, and if you use the correct GM adapters and a th350 the cross member dosen't have to be moved, and the drive shafts don't need any mods. ( The adapters are different lengths and the take up the difference in trany lengths ) I don't know if this is true if you use an after market adapter !!!!! Other items you will need !!! Auto steering coulomb Auto pedal set-up Auto trany linkage Radiator with cooler or good trany cooler trany fluid lines Trany kick-down cable & bracket Trany dip-stick & tube Good luck with your conversion. Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 08-17-2005 at 07:35 AM. |
