How did you install your trans cooler?
I have a 10"x10"x3/4" hayden trans cooler that I want to install along with the radiator cooler. I'm having some difficulty in figuring our how to run the extra cooler lines without having to hack any of the radiator support. I would appreciate any pics of how any of you have tackled and conquered this task...
Thanks in Advance!!! donovan
78 C10 LWB Super Cheyenne |
![]() ![]() Join Date: Jan 2005
I installed a Hayden cooler on my truck. I didn't want to cut up my transmission cooler lines so I purchased Hayden part number 393, which is a pair of flexible hose barb fittings: one threads into the radiator, and the other attaches to the end of the cooler line.
Thanks for the update and pictures... I'll take a look and see if I can find those here locally.
I used bulk head fittings...worked well
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
Have any pictures that you could share? It sounds interesting...
I don't remember the size of my cooler, but it is a perma-cool cooler. I attached it to the front of the radiator support with 4 aluminum peices. I bought adapters to take the radiator and transmission ports to Braided Line. Also, added the thing for a tempature sending unit.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
I just realized that the bulk head fittings only fit with out the battery located in the front. Until I moved the battery to the back I had it run like low69cst.
That looks great low69cst! Thanks for the pictures...
![]() Join Date: Dec 2004
i just used a a/c condenser(now thats a freakin cooler) i just ran 3/8 braided line from my tranny to the cooler
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
i used pcv grommits and bored holes in the core support to run the hoses through. no cut hoses and was cheap
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
I used the AC condensor mounting brackets from a 1971 Monte Carlo that I parted out. I can't remember what brand of cooler I used but it works good.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
This photo is a view looking down on the cooler with the radiator on your right. The black thingie on the left of the cooler is a fan controlled by a switch on the dash.
![]() Last edited by gator2511; 08-17-2005 at 06:49 PM. |
#13 |
![]() This is the passenger side behind the grille. I put a tranny filter in here. I ran my tranny lines straight to the cooler and filter and plugged the radiator. It doesn't get that cold here and I can get away without running the lines through the radiator for heating in the winter. |
