Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 08-13-2005, 10:27 PM   #1
whitesswj
Embrace the Redneck
whitesswj's Avatar
Exclamation WTB a 4 or 5 spd
I'm looking to save gas money and i was told to look to y'all for a 3 spd w/ 4 o'd or a good 5 speed,
I've got a 350 in a 68 not real worried about length of tail or any of the such, may not even need the bell as the one i have my bolt right up. I've currently got a sag 3spd on it.
I'm in Hannibal MO which is 100 Miles North of ST Louis.
PM me if you can help.
thanks SSWJ
'01 Camaro
Son, you just can't get there from here...
whitesswj is offline   Reply With Quote
Old 08-14-2005, 05:58 PM   #2
bisquik65
bisquik65's Avatar
You can get a 5speed out of a 86-90 s-10 that has a 2.5 its a borg warner trans and will bolt up to your orignal bell housing,but you have to cut a hole in the floor for the shifter as its a top loader,If you dont beat them they will last...
bisquik65 is offline   Reply With Quote
Old 08-15-2005, 01:09 AM   #3
whitesswj
Embrace the Redneck
whitesswj's Avatar
do you have experience with this modification?
What is your definition of "beat" it?
And, what kind of spedo hookup does it have, cable or electronic?
Also, will the splines in the input shaft match the ones from the old tranny so i won't have to change out the flywheel and clutch system??
thanks sswj
'01 Camaro
Old 08-15-2005, 08:31 AM   #4
bisquik65
bisquik65's Avatar
thanks sswj
You would need to not put it in like 3rd gear and floor it...you know...They will hold up some,same trans is found in camaros,but the f-body ones are tilted and wont work..
The early ones pre 89 88 and older have speedo cable drive..
And the clutch is a 26 spline ,but you just need a disk from a v8 camaro
No just change the disk out ,Get one from a 85-92 with a v8
This is about the easiest swap to do and trannys are out there for a good price too.
PM sent
Old 08-17-2005, 12:03 AM   #5
whitesswj
Embrace the Redneck
whitesswj's Avatar
thanks a big one for the "help"! biz
'01 Camaro
Old 09-18-2005, 11:52 PM   #6
whitesswj
Embrace the Redneck
whitesswj's Avatar
You mean if you're at highway speeds(70 MPH) and you want to pass, don't put it in 3rd and go, right?
I've got an 11" disk right now. Will that be the same as the 26 spline from the Camaro??
thanks for all the help thus far, SSWJ
'01 Camaro
Old 09-19-2005, 08:51 AM   #7
bisquik65
bisquik65's Avatar
The camaro clutch is a 10.5 one..so it is not that much smaller,You can get a good 26 slpine disk from jegs or summit...
Yes , Just not anything like that,Now they will take a beating...but i was talking like a 400hp motor and just flat out wide open then dumping the clutch...Its wont last that way... You do not want the getrag style trans that has the bellhousing made to it..Those are junk...
I am getting ready to do this swap to my 70 2wd blazer..the T-10 is in need of overhual,and i want o.d. so..Its going to get done...
Old 09-19-2005, 09:36 AM   #8
whitesswj
Embrace the Redneck
whitesswj's Avatar
so i wouldn't have to switch out flywheel or pressure plate right?
sswj
'01 Camaro
Old 09-19-2005, 11:34 AM   #9
greg0380
I just did this swap a week ago. I replaced a SM465 with a 5 speed/OD out of an 89 Scottsdale. These trans are different than what you have now, the bellhousing is part of the trans. It will bolt to your 350. THere may be some mods, like the clutch. The 5 speed I have, used a hydraulic clutch which you would have to use because the throughout fork is on the passenger side. The input shafts should be the same (10 spline), you will have to check the output shaft. The 5 speed has the driveshaft that slides into the back of the trans, unlike the SM465 that has a universal joint right at the output of the shaft.
1985 GMC Sierra 1500, 1/2 ton, 2WD, LWB, TBI 305
5 speed, 3.42 rear
2007 GMC Sierra 1500, xtended cab, 4X4, flexfuel 5.3L
1999 BMW 528i
greg0380 is offline   Reply With Quote
Old 09-19-2005, 03:56 PM   #10
bisquik65
bisquik65's Avatar
sswj
The disk is all you need to change...
And greg0380 Please give me a pm. i have not forgot you...Thanks,Erick
Old 09-19-2005, 04:31 PM   #11
boraxman
Keepin an eye out
boraxman's Avatar
Let me know if you need a clutch kit, have a new 10 spline w/pp & TO bearing $75 to the door.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 09-19-2005, 10:46 PM   #12
whitesswj
Embrace the Redneck
whitesswj's Avatar
will this work w/ the borg warner tranny?
'01 Camaro
Old 09-20-2005, 12:07 AM   #13
boraxman
Keepin an eye out
boraxman's Avatar
Not sure its 10 spline, 10.5" across, made by McLeod.
ZIP 91351
