08-14-2005, 12:07 AM | #1 |
hedman headers hitting frame
talked to hedman via email and summit on the phone and they both suggested part number 69096 for ceramic coated headers for my 72 suburban 2wd TH350 with ZZ4 motor.
hedman makes a d-port header I have since found, but they sent me these? the gasket cut off about 20% of the flow. the header hit the frame on the passenger side, and only a fraction of an inch on the drivers. the bracket they sold me to fit the factory long pump style A/C doesn't fit. the header sticks down so low below the frame that if anything hits a bump, the headers are going first! which I guess also means the aluminum heads. anybody else have any luck. or any suggestions with these headers or recommend somthing else? I was really dissapointed after spending ALL day trying to get this motor in. was really hoping to fire it up tonight!!! |
08-14-2005, 02:11 AM | #2 |
Thats the Hillbilly way
You might want to check the motor mount on the side the headers are hitting the frame , I had a similiar problem that was a worn motor mount .
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
08-14-2005, 09:41 AM | #3 |
just put brand new motor mounts when I put in the new motor. I thought maybe I needed to move the motor around, but there is not enough room on either side to make room for the other.
08-14-2005, 10:56 AM | #4 |
all I can say is I'm not to impressed with my headman headers either. I have a chevy 400 and they hug the engine so close that all the boots on my malorey wires are cracking or melting. I have 1 cable that I have had to replace 3 times cause it actually melts the wire.
'72 custom 20 Current mods race built chevy 400 engine. over carbed =/ Powder coated bumpers Progressive Wheels Future mods single windows. alum. fuel cell under bed, sidemarker fuel cap mod. All white and yellow interior. leather bucket seats. |
08-14-2005, 05:28 PM | #5 |
I have hedmans as well, although they are not the ceramic coated variety. After I installed my 350 I found that the headers were contacting the frame on both sides, although much more on the passenger. I ended up just clearancing the frame with the grinder...
78 C10 LWB Super Cheyenne |
08-14-2005, 05:54 PM | #6 |
i have ceramic coated headmans on my 400 small block. They don't hit the frame (that I can tell) but are very close. I did have to reroute the brake line that shoots toward the rear. I would do as mentioned above and get out the grinder.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
08-14-2005, 09:49 PM | #7 |
yep grinded it! it fits now.
and it fired! |
08-15-2005, 07:11 AM | #8 |
Nobody rides free
Wow, you guys are startin' to scare me, I just got mine Friday & haven't got a chance to put 'em on yet. I hope I have better luck than you guys seem to. They look great though, I just hope my mufflers hurry up & get here.
'71 C10 LWB 400SB/350TH '86 K2O LWB 350SB/400TH-6" tuff country lift, Shackle flip - plow truck '06 HHR - wifes wheels '01 Blazer - daily driver "It's better to burn out than it is to rust." -Neil Young |
08-18-2005, 12:53 AM | #9 |
I recently replace Hedmans on my '72 swb with Thorleys. Definatley worth the trouble.
08-18-2005, 01:01 AM | #10 |
All Praise RANDY!!
Jay, what did the thorleys run you, and if you dont mind, what part #did you run?
Thanks NutZ |
