how much hp, can th350 handle?
im having a 396 bb built up for my 72 shortbox, i want to install a th400 but not looking forward to getting a different yoke and gettting the shaft cut..... should i just stay with a th350? or is it worth the work to a th400? thanks!
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
turbo350's can be built to take over 800hp
I had one built for my Model A running a 6:71 blown 350 (ported heads and all that other crap)...680 horses.
Chevy Freak
th350
Ran 9.12 on one in a 73 camaro.
69 GMC SWB, 350 70 Chevy LWB, 350 55 chevy gasser, 461 73 Camaro, 496 67 RS Camaro, 406 64 Chevelle, 588 71 Nova, 565 67 Camaro, 461 |
![]() Join Date: Apr 2004
They are a lot tougher than given credit for!
1968 Chevy 4x4 307 4 speed |
My friend ran one in a lifted 77 4x4.. big tires, 500hp 454.. tranny outlasted the truck.
Got Big Block?
are you rebuilding the TH350? It's doubtful any of the one's mentioned are anywhere near stock. They can undoubtably be built ($$) to withstand alot of punishment. It also depends on how bad your going to treat it(just street tires or track/slicks...). For peace of mind I went ahead and swapped in a TH400, because I didn't want to be swapping transmissions frequently. Most likely, if you're talking about a cruiser/ street tire smoker, the 350 will be fine.
"Experience is what you get when you didn't get what you wanted." Last edited by Purs; 08-14-2005 at 02:31 PM. |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
I have a T350 in this. 612hp, 738ft tq. Definately not stock but not too bad. $250 in the rebuild and $400 in the converter. Has a manual valve body, shift improvements, ect.
#10 | |
Got Big Block?
"Experience is what you get when you didn't get what you wanted." |
Born a Chevy Man
ratrod67, Bad ass car you have there. Nice. Love the yellow with the black strips.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) ![]() ![]() If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! ![]() GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
#12 | |
#13 |
Originally Posted by junkyardjohn
GENERAL MOTORS NEVER PUT A T-350 BEHIND A BIG BLOCK. JOHN They never put one in a Model A Ford Either. GM also put the best truck motor in a car! ![]()
#14 |
Epoxy Primer Friendly
Th___
Make sure you get the heat treated sprag and drum no matter what.. The sprag is the weakest link in the Turbo trans. You also get to keep a little more power with the 350 over the 400. Go with the TH350
#15 |
Run it!
Keep the 350 unless it acts up and then worry about an upgrade. I ran a stock one in a Buick Stage 1 455 with a slight cam with only a B+M shift upgrade kit and it lasted thru 2 drag seasons with 0 problems! I sold the car
#16 |
Matt,
I am running a TH-350 on a 72 LWB with a 450hp 402. I spent about $450 on a rebuild and I don't anticipate any problems at all. BTW, I think you will need to have the drive shaft shortened as a result of the BB. You will want to mount it in the forward set of frame holes to allow maximum firewall clearance for the distributor. Good luck. You will love the performance. Larry |
#17 | |
Born a Chevy Man
