now I did it 80 chevy ques....
I have a 80 Chevy 1 ton dump for work. The other day, 3rd gear (well, second if you do not count granny) started jumping out. Today, I pulled the cover/shifter and took a look see. The gears all look fine, not spare metal in the case. I was playing with the shifter out of the truck and it will not shift. It also will not set back down in the tranny. Basicly what I am asking, did I screw myself, or is it something simple I am just not seeing?
Thanks, Jeremy |
Done yet?
Our 85 dump pops outta 3rd all the time unless you hold in it there. I never took it apart though so I can't help you there.
'76 k2500 -- almost done... |
Professional Grade
I'll have to take a look, but there was a wicked FAQ on the 465 trannies on ck5 before. I think it covered the dissassembly and fixing and reassembly of the 465s falling outta third problem. Lemme try and find it, and if so, I'll post it up
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
#4 | |
Professional Grade
This covers how to fix the 465's slop, next I'll try and find out how to dissassemble and reassemble it.
Professional Grade
Ok, I don't have an indepth article to post, but it seems that you need to carefully align the reverse gear to get the top to drop back down. Apparantly, its a real pain in the butt, and you'll need a whole lotta patience to get it back on...
I'll keep looking for something a bit more indepth...
california fill
if im reading this right-- all you need to do is align the forks down in that hole that the shifter drops into... if they're not aligned properly (been a few years since i done it) the shifter will just be "stuck".... its pretty simple fix, get a flashligh and a big flathead screwdriver and line em up...
pc |
