Old 08-14-2005, 09:04 PM   #1
71Dragtruck
71Dragtruck's Avatar
I'll start the what got done on the weekend.
Well I might as well start off with what I got done. I relocated my battery to the back, put the cut off switch in the bumper, and mounted the remote terminals under the hood. I also replaced my plastic fuel cell with a aluminum one, redid the fuel line with a billet suction filter and shut off valve. I would have posted a pic of the hole I cut in my dint free box for the sump, but I didn't want to make the "keep her original" guy's upset.
71Dragtruck is offline   Reply With Quote
Old 08-14-2005, 09:14 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
My oldest(10) helped me tighten down all the bolts in my 8' stepside bed floor, and install the steps I had. Got the form up for my driveway, got 9 yds coming tomorrow.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-14-2005, 09:22 PM   #3
woodman13
woodman13
I installed header gaskets on a 1996 Formula LT-1(hooker super comp headers) pain in the A$$, replaced a dip stick tub on a 1995 Camaro, installed headers, plugs, built a bracket for my alternator on my 1969/1971 Chevy truck, installed a Hurst shifter(had to replace a section of aluminum floor some dumba$$ installed to mount the shifter on, and tryed to get it running. Straightened the shop(happens every weekend) and drank all the beer in my shop!
Woodman13
2007 Dodge Ram 3500 5.9 rolling coal!
1994 Caprice 9C1 88K miles, LT-1, dropped/shaved
1967 C-30 350 4 sp dually
1971 C10 SWB BBC, auto; good driver
woodman13 is offline   Reply With Quote
Old 08-14-2005, 09:22 PM   #4
Jimbotronics
YA YA
Jimbotronics's Avatar
Man that's a sharp application ya got there Drag!
I actually got to work on my project for the first time in several months. Learning as I go I'm doing a cab swap. Got everything outta the cab except front/rear glass, fuel tank, steering column, and brake assembly. Not sure how to go about removing the glass so I'll probably have to do a Q&A post on that...lol
Jimbo
'72 SWB - 350 (frame-off resto in progress - donations accepted)
'04 Chevy Avalanche
'03 Cadillac CTS (wife's ride)
Restoration progress - http://67-72chevytrucks.com/vboard/s...d.php?t=335707
Jimbotronics is offline   Reply With Quote
Old 08-14-2005, 09:24 PM   #5
68gmcdually
68gmcdually's Avatar
I started the truck and moved it 10 feet over in the driveway. There done.
James Bellwood
1968 930 Extend-A-Cab Dually 5.7l, 5 speed,
68gmcdually is offline   Reply With Quote
Old 08-14-2005, 09:59 PM   #6
jc
jc's Avatar
got the 71 regestered and insured friday and on saturdaydrove it more than 50 feet for the first time.
3 miles to be exact
thats all i had time for had to go to work, besides i didnt wanna were out that (my new truck) feiling.
man what a smooth ride.
im off for the next 3 days you can bet ill be going for i little cruise this week.
gotta show here off
2004 Silverado 2500HD Crewcab 4x4
2000 TOYOTA 4RUNNER
1971 CHEYENNE LWB (THE LOVE SHACK)
1967 c-10 lwb (THE FARMERS DAUGHTER)
jc is offline   Reply With Quote
Old 08-14-2005, 10:06 PM   #7
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
Welded in the patch panels on my hood brace panel. Turned out pretty good.
Jims70GMC- Watch the heat tomorrow! You better move fast with that concrete, in this heat it'll set up fast.
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
Old 08-14-2005, 10:16 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
ummm, I tightened up the alt belt on my worthless bro in law's chevy tracker.
oops, i ment my bro in law's worthless chevy tracker.
no I didn't...I had it right the first time.
Old 08-14-2005, 10:17 PM   #9
mocwon
Keep On Truckin'
mocwon's Avatar
Sweated my a$$ off in 100 deg Texas heat
Fabricated and installed three point seat belt brackets, modified and installed Mazda fuel door opening mechanism, installed Firebird side marker lights, wired up A/C compressor, installed hood lock, plumbed gas tank vent, measured requirements for TPI tubing and several other punch list items.....
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 08-14-2005, 10:22 PM   #10
Deuce
Deuce's Avatar
What are you going to use for TPI ducting?? I'm at that point now. I was going to use 88-89 Firebird ducts.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 08-14-2005, 10:34 PM   #11
71Dragtruck
Same here oldest daughter 12, backed up the bolts on my cell for me
Old 08-14-2005, 10:52 PM   #12
Randy70C-10
Randy70C-10's Avatar
I helped Wootdogs brother Josh do some bodywork on his truck bed, and my daughter's prom date shot a couple coats of paint on the cab. Josh shot a couple coats too, we'll have some pics to post soon.
Randy70C-10 is offline   Reply With Quote
Old 08-14-2005, 10:52 PM   #13
mocwon
Keep On Truckin'
mocwon's Avatar
Used Firebird 90 deg rubber adapter from throttle body to MAF sensor. Plan on using 3" tubing over to K&N filter on passenger side (battery was moved to driver side). Originally planned to use C5 Corvette filter but a local turbo company convinced me otherwise.
Just Passin' Thru
Old 08-14-2005, 10:57 PM   #14
71Dragtruck
Oh since I haven't used my washer fluid in 17 years, I also removed the bottle and bracket, just to balance the weight I lost from the battery LOL.
Old 08-14-2005, 11:50 PM   #15
al's71gmc
4 eyed fever
al's71gmc's Avatar
installed my lift kit and shocks. PITA to do without a gas axe for those 35 YO u bolts!! but it sure looks nice! also installed new header gaskets(again). this time i took advice from you guys and used regular manifold gaskets and hi temp sealer. it sounds good now, i just hope it lasts for more than 3k miles.
1971 GMC 2500 4x4
1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto.
4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!!
al's71gmc is offline   Reply With Quote
Old 08-15-2005, 12:43 AM   #16
skokie
skokie's Avatar
I picked up a 327 for my 68.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 08-15-2005, 02:20 AM   #17
hgs_notes
GEARHEAD
hgs_notes's Avatar
I went to the NHRA drag races in Brainerd saturday. I took my wife and son (9 and a total gearhead). We watched Tony Schumacher break more track records and almost the NHRA record for mph at over 337. He ran twice with ets of 4.44 and 4.48. Oh yeah, they all ran well and it was my first time back since 1995, before the boy was born. There may be some correlation between the mother breathing in all those nitro-methane fumes and tire smoke and him being afflicted with gearheadedness. I can think of worse things, but he has a long, sometimes painful, therapy to deal with. I'm trying my best to be understanding and supportive of his interests, but dammit, he wants to take my truck in a few years, then I'll have to find new therapy. My oldest girl is named Shelby, for the AC Cobras. Maybe I'll buy a kit...
HG
hgs_notes is offline   Reply With Quote
Old 08-15-2005, 05:33 AM   #18
I opened the door to the shop and saw my truck as I pulled out the mower. I was on the road most of the weekend driving to and from my daughter's school. Mowed the pasture land, least it seemed that way in the heat/humidity.
Old 08-15-2005, 07:24 AM   #19
68C15
blood type; Retumbo
68C15's Avatar
I recieved shipment of a 67 short step project from another member. it came with a butt-load of extra parts which needed a home. then I cleaned ou the garage & reinforced the roof joists. (gotta make room for parts up above) then I got a call from Dean & Crystal saying they are about 2 hours away. we ended up with a total of 5 board members here for a mini meet. I had a great time BSing with all of them. thankfully I had a pair of Honda buckets & a Chevy bench seat. sorry, no pics, the batteries in digicam were dead.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 08-15-2005, 11:28 AM   #20
72str8flush
72str8flush's Avatar
I fixed my power steering pressure hose leak :crosses fingers: And worked on degreasing the engine from months of PS fluid leakage. PO thought the way to fix the leak was just to fill more PS fluid in the resevoir.
Oh yea... did a lil of this too.
72 Chevy Short Bed Fleet: 350/TH350 - Sold - Now trying to sell the parts that I have left over.
_______________________
2006 VW GTI
72str8flush is offline   Reply With Quote
Old 08-15-2005, 11:49 AM   #21
farside847
farside847's Avatar
I replaced my heater core, man what a PITA.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 08-15-2005, 12:17 PM   #22
ronh72c10
Finished up replacing the inner rocker, kick, front pillar and outer rocker on the passenger side of the Burb. Now it's time to move onto the driver side.
Ron
72 Chevy C10 (rust repaired, starting body work)
72 GMC 3/4ton 4x4
72 Chevy C20 Suburban
38 Ford Tudor Humpback Sedan (from the darkside)
67 Pontiac Parisienne
55 Studebaker Commander 2dr Hardtop (Starliner)
My Youtube channel with Video Updates!
ronh72c10 is offline   Reply With Quote
Old 08-15-2005, 12:50 PM   #23
cdowns
cdowns's Avatar
no car related stuff/ fri and sat nights i was up min the attics ran a new bigger improved 8" ac duct so it dumps right in the middle of the shop for better more even cooling/also in the house attic ran the duct for the kitchen vent hood, also had to reposition the v220v line for the stove and ran new circuits for the dishwasher,venthood,and accessory outlets
during the days i rented a heavyduty planer/ been slo drying and curing these new england tight grained oak planks for almost 3years 16-18" wide by 31/2thick by 8-10' long so i was busy planing ripping and cutting to dimension for cabinet and shelf projects// got them inside storeage for the final drying session 3-4months b-4 final sanding to dimension// got huge bags of oak sawdust and shavings to dispose of now// hopefully i'll be able to finally finish up the kitchen b-4 speedweeks next year
Old 08-15-2005, 02:22 PM   #24
72str8flush
Don't say that... its on my to-do list.
2006 VW GTI
Old 08-15-2005, 05:21 PM   #25
70GMCer
70GMCer's Avatar
Installed my new Edelbrock carb, & old restored, MT valve covers. Then I started the motor and watched it over heat !! I'll tackle that problem next weekend.....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
