Old 08-14-2005, 11:24 PM   #1
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
Dual a/c connection???
I am going to run front and rear air on the Blazer I am working on. Anyone know of a diagram or anywhere I can get info on this type of setup. Do I just "T" into the front lines?? Please help, Confused in E.Tex.
FuelCellGuy is offline   Reply With Quote
Old 08-14-2005, 11:53 PM   #2
neonlarry
neonlarry's Avatar
The burbs I have seen with front and rear air just T or Y the front lines.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 08-14-2005, 11:57 PM   #3
Bob Moore
Check the factory assembly manual for the Suburbans with rear air and regular air.
Good luck - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 08-15-2005, 01:40 AM   #4
masterbeavis
Having issues
masterbeavis's Avatar
tee the lines. Its how it was done on my centurion.
Quando Omni Flunkus Moritati.
The Man's Prayer: "I'm a man, but I can change, if I have to, I guess."
masterbeavis is offline   Reply With Quote
Old 08-15-2005, 07:29 AM   #5
68C15
blood type; Retumbo
68C15's Avatar
short answer.
"T"
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 08-15-2005, 07:31 AM   #6
FuelCellGuy
FUEL CELL GURU
Thanks!! Easy enough. Later!!
