08-15-2005, 11:05 AM | #1 |
Still Green but learning
What yr is what
I have a 71 and I know the easiest and most visable way to tell a 71 from a 72 is the rearview mirror mounting and the door panels.
what about 69-70, and 67-68. What are the obvious differences so I can make new friends and impress others?
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
08-15-2005, 11:33 AM | #2 |
Questionable
67-78....all I know is this: some of the 67's had a small back window and all of them came without the front chrome trim "eyebrows". It an be confusing though, because some of the '68's also lack that trim and some of the '67s also have large back windows
Can't help you on a 69-70 trucks. I really like the 67-70's. I think the '71 and '72s are ugly as sin. Something about the front end on the 67-70'2 just really makes it look seriously hot.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
08-15-2005, 11:36 AM | #3 | ||
08-15-2005, 11:40 AM | #4 |
Questionable
Sorry, Phlegm. You can always put a '67-70 front end on it
LOL (It's just my opinion. I bought a '68, so I'm rather partial )
08-15-2005, 11:53 AM | #5 |
All 68's have side markers while 67's don't (Most of them are just reflectors in 68). Many 68's have white face and extra chrome trim around the front lip of the hood and fenders. 68's have grey painted wheels and poverty hub caps. (68 Hub caps have orange/black highlights) Most 67's have either body colored wheels or black wheels with white poverty hub cabs (Except orange bowtie and highlights.) 68's have later style arm rests and somewhat different options availibility.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
08-15-2005, 11:59 AM | #6 |
69-70 are the hardest for me to tell apart. I'm pretty sure that the style of the plastic inner grill was different. I believe one year had a grid, and the other had louvres. It's hard to tell from a distance.
08-15-2005, 12:08 PM | #7 |
Questionable
I thought 69-70 had a steel inner grille?
08-15-2005, 01:48 PM | #8 |
Watch out for your cornhole !
It's plastic
08-15-2005, 01:55 PM | #9 |
Questionable
Wait - is there an inner and an outer grille? What do you consider the metal part with "CHEVROLET" embossed in it?
08-15-2005, 01:57 PM | #10 |
Outer
08-15-2005, 02:01 PM | #11 | |
blood type; Retumbo
oh, & get this, my rear view mirror is screwed to the roof with 2 screws & a stamped metal piece. the mirror is a simple laminated unit with no day/night control. the glass part is about 3"x5". WTF??? as far as 69-70 goes, didnt they switch to a throttle cable in 70?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
08-15-2005, 02:02 PM | #12 |
Throttle cable in 71. 70 still used the rod.
08-15-2005, 04:14 PM | #13 |
Although you visually can't see it, the 70 also has the wider rear axle like the 71/72 (about 1" wider if I remember). But yes the 69 and 70 are the hardest to tell apart, because visually the only difference is the inner grill pattern and they neven made 70 replacements, so if the inner grill was ever replaced, dealer or otherwise, they got the 69 innner grill (egg-crate style). The 70 has 9 rows (i think) of little chrome trim pieces.
I also believe all 70's had side marker light standard, instead of reflectors.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 08-15-2005 at 04:16 PM. |
08-15-2005, 09:36 PM | #14 |
its all about the +6 inches
Some 68's did have the old style arm rests. Fine69's old 68 one ton dump truck had them.
The flat style mirror arm... it probably isn't original. The mirror was an option untill 70 when it became base model equipment. |
08-15-2005, 10:09 PM | #15 | |
blood type; Retumbo
08-15-2005, 10:37 PM | #16 |
is it on the option sheet?
08-16-2005, 07:32 AM | #17 |
blood type; Retumbo
I have no option sheet. not even a sign of one. I'll try to take a pic of my mirror & armrests and start a thread in the truck board.
08-16-2005, 08:44 AM | #18 |
There are alot of differences between the 67 and 68. The first and most obvious is the side marker lights which has been mentioned. Second, 67's had a small back window standard with a big back window as an option. The grill area was painted body color with the trim and headlght bezels painted white or the polished aluminum in 67. The 68 grill area was painted white to please government standards(they were supposed to be easier to see) with painted steel or aluminum trim and bezels. Many people repaint the grill area body color with aluminum trim for a cleaner look so this is easier to tell on original unpainted trucks.
Interior differences are few. The 67's carried alot over from 66 models. The vent window handles are the same and alot(not all) had armrests from the 66. The ignition swith bezel was smaller in 67. 67 was the last year for the 283. The 68 was the first year available with a BB and the 307 SB. It was also the last year for the 327 SB. As mentioned before, the only difference in the 69 and 70 is the inner grill, the wider axles, and another difference is late 69 and all 70 models used the bigger 605 power steering box. The 69 and 70 also carried the 396 name badge but they were 402's. The 71-71 models had the 400 badge with a 402 BB, but never had a 400 SB. Most people know this but I've actually seen guys almost get in fist fights over the 400 option.
08-16-2005, 01:00 PM | #19 | |
What is the deal with the headlight bezels on a 69-70. Some are painted black and others are alunimum (unpainted).
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
08-16-2005, 01:03 PM | #20 | |
08-16-2005, 01:07 PM | #21 | ||
Far as I remember, factory was painted, but they only make the aluminum or polished as replacements. Quote:
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 08-16-2005 at 01:11 PM. |
08-16-2005, 02:03 PM | #22 |
Nobody rides free
So, this too may be a dumb question but what about the bowtie on the front of the hood vs. in the middle of the grille? I saw a truck almost like my '71 but the bowtie was centered on the front of the hood.??
edit: my '71 has a cable, not a rod but it also has a 400sb so cable could have been during the transition.
'71 C10 LWB 400SB/350TH '86 K2O LWB 350SB/400TH-6" tuff country lift, Shackle flip - plow truck '06 HHR - wifes wheels '01 Blazer - daily driver "It's better to burn out than it is to rust." -Neil Young Last edited by bowtier; 08-16-2005 at 02:05 PM. |
08-16-2005, 02:12 PM | #23 |
The last 71 I parted out was a T-cable setup.
08-16-2005, 02:29 PM | #24 |
This site might be a little help to this discussion. Click here
72 Chevy Short Bed Fleet: 350/TH350 - Sold - Now trying to sell the parts that I have left over. _______________________ 2006 VW GTI |
08-16-2005, 02:42 PM | #25 | |
I was just about to post that myself.
67 C10 LWB Stepside- 250cid 6, 3speed |
