Old 08-15-2005, 12:17 PM   #1
Eyegore
What Hump?
Eyegore's Avatar
a/c r134 question
How much freon is needed for an 86 c-10, I called an a/c shop and was told 48 ounces, a friend told me that is to much. So does anyone know the amount specified by the manufacture?
Thanks ahead of time.
Tom
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 08-15-2005, 02:22 PM   #2
bodydropped
3 cans is what i got in mine
bodydropped is offline   Reply With Quote
Old 08-15-2005, 10:01 PM   #3
sameyrasmea72
sameyrasmea72's Avatar
3 cans sounds right or 3 lbs=48 ounces
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 08-15-2005, 10:51 PM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I think the cans are 12 ounces, which would be 4 cans for 48 ounces.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 08-15-2005, 11:30 PM   #5
Eyegore
What Hump?
Eyegore's Avatar
Well that is what I was told at the suppply store but as we began to check the system we released some to where it was about 2.5 lbs and we got a lower tempature. The friend who was helping me said he thought that 3 lbs was to much, perhaps a suburban w/ 2 coils, but not for a single cab truck. Does someone have the tech manual that gives the exact amount?
P.S. thanks for your replies!
Lil red 86 c-10
99 Sub
Old 08-16-2005, 02:25 AM   #6
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
My 83 shop manual lists a refrigerant charge of 3 lbs - 12 oz for C-K models with a C60 system. BTW, C-K models with a overhead system take 5 lbs. - 4 oz.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 08-16-2005, 03:44 AM   #7
ureckme
ureckmefixit2@cox.net
This is a 134A Question, When you retrofit a R12 system to 134a you use 85% of what the system used factory, so if the system used 1LB of R12 you should use .85LB of 134A. Low side should be around 35 to 40LB to make it colder use a 134A condencer. But mine works just fine with out. Get a 18inch fan and fan clutch. Matt
That's U RECK ME FIX it 2
74 Chevy Short Bed
355ci Sportsman II 64cc Angle Plug
Crower Custom Grind .462in .486ex
Dyno Test 422hp @ 5600
And it's got a Holley
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
I'm a Body Man So There!
That's why it's not painted
ureckme is offline   Reply With Quote
