Old 08-15-2005, 12:31 PM   #1
newin72
shimming a starter
got the new ZZ4 in and had to go with a new flywheel. starter is pretty strained now, what is the best method to shim the starter?
I have never done it before. how do I know what size shim to use etc.???
thanks!
newin72 is offline   Reply With Quote
Old 08-15-2005, 12:35 PM   #2
fade94
fade94's Avatar
Insert a 1/8 rod between the starter gear and the flywheel. Easiest way to do this is to take of the solenoid so that you can engage and disengage the gear by hand. bolt up the starter and check the spacing with the rod. If it's too tight, add a shim to the INSIDE hole. This will increase the distance. If its' too far away, add shims to the outside hole..
Hope this helps.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 08-15-2005, 02:05 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
fade94, this is partially correct. it should have 1/8" gap between the starter shaft & the ring gear.
you have new engine (not reman) & a new flywheel? get a new nosecone for the starter & it should fit like a glove without shimming.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 08-15-2005, 05:45 PM   #4
newin72
yeah a ZZ4 engine and new flexplate.
a new cone?? where I get that?
Old 08-16-2005, 04:06 PM   #5
krue
Designated A-hole!
krue's Avatar
Try an auto electric shop. They should have what you need.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
