hood alignment...
My hood rubs on the cowln when I open it. What bolts control this movement? Should I try and move the hood, or the cowl? I messed around a bit with the cowl and it really didnt want to move any futher back, all those screws keep it in place even when I loosen the 4 bolts. Any suggestions?
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
Are they at the same height? If they arent then they open on different planes. If they are the same height try moving the hood forward by loosing the 4 bolts that connect the hood to the hinges.
Ok, I will try that. I didnt know the hood to hinge bolds were adjustable. Thanks.
![]() ![]() Join Date: Jan 2005
If you end up moving your hood forward, you may need to move the latch post back to compensate.
