Old 08-15-2005, 01:57 PM   #1
79Silv4x4
Workaholic
79Silv4x4's Avatar
Reasonable price for gear change?
I recently installed a lift kit on my '91 Suburban and need to have the gears swapped out for some lower ones. Local drivetrain shop quoted me $650 labor. Sounded kinda high to me. Opinions. . .Suggestions. . .
79Silv4x4 is offline   Reply With Quote
Old 08-15-2005, 03:11 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Was that for both axles still in the vehicle? if so, that is CHEAP!
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 08-15-2005, 03:31 PM   #3
79Silv4x4
Workaholic
79Silv4x4's Avatar
Yes, both axles in the vehicle. Total with parts and labor was $1250. I know I can do better on the parts . . .
Old 08-15-2005, 05:14 PM   #4
Captkaos
Captkaos's Avatar
Ok, I misread this, but is still isn't that bad. Here they charge $300 per axle if it is still in the vehicle. Parts you probably can do better on.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 08-15-2005, 06:14 PM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
Let's see---lift the truck, remove drivelines, drain carrier housings and remove axles, remove old ring and pinion sets, remove ring gears, install new gears, install pinion shafts, install carrier, set backlash, install axles, install drive lines (inspect U-joints for wear) fill with new lube. You know $1250 is not all that bad, ask what they would charge if you had your own ring and pinion sets? Sometimes it is better to pay just a little more and get it done once and for all, instead of working the monkey for some small change.
piecesparts is offline   Reply With Quote
Old 08-15-2005, 06:15 PM   #6
79Silv4x4
Workaholic
79Silv4x4's Avatar
Yeah, I guess it's not out of line b/c I called a couple other places and received similar quotes. It wouldn't be all that bad if I were only doing one axle.
Old 08-15-2005, 07:03 PM   #7
1FaastC10
1FaastC10's Avatar
swap to 3/4 tons. that's going to be cheaper than the gears and install for one axle, then buy a set of 8 lug wheels that will fit your tires, and you're golden. that 10 bolt wont survive those tires for very long. the 8.5" 10 bolt carriers are notorious for being weak. when they fail, they take out the ring and pinion too. i broke mine with bald 245 75 16s on it, and was being easy on the truck (heavy traffic).
1FaastC10 is offline   Reply With Quote
Old 08-16-2005, 12:44 AM   #8
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
What gear ratio you looking for? I've got a 3.40 set for a 12 bolt for sale. If you wanted an axle to get geared and swap out I have one as well plus I'm close to you.
I guess I got lucky on my rear axle being rebuilt for $100. I got quoted here in town $250 per axle brought in not on the truck.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 08-16-2005, 07:38 AM   #9
bigarmzz
bigarmzz's Avatar
around here that price is "insane"
there's a local guy that sets up most all rear ends around here, he's the best, he only charges $150 a rear
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 08-16-2005, 05:12 PM   #10
see ten
WTB this ad
see ten's Avatar
There is a garage down the road from here that I use that charges $200 labor per axle. When my brother was in tech school I had them regear a truck for me for the cost of the parts. If you have a tech school remotely close to you give them a call. The students have to have projects for their grades and the instructor will make sure the work is done right.
see ten is offline   Reply With Quote
Old 08-16-2005, 05:38 PM   #11
79Silv4x4
Workaholic
79Silv4x4's Avatar
Thanks but I have 3.42 right now and looking to go to 4.10.
Old 08-16-2005, 05:39 PM   #12
79Silv4x4
Workaholic
79Silv4x4's Avatar
Yeah, now that the vo-tech is open I might check into that. . .
Old 08-16-2005, 05:40 PM   #13
79Silv4x4
Workaholic
79Silv4x4's Avatar
14 bolt SF for the rear but what about the front. Is an 8 lug D44 the way to go?
