Old 08-15-2005, 06:45 PM   #1
71-longbed
Its Magically Delicious
71-longbed's Avatar
arm rest help
I can't for the life of me .. get my armrest screws in my 71 to break loose .. i've tried all the penatrating oils i have and and nothing will knock er loose
Any suggestion on what i should try next ... i've got another nice arm rest but i dont want to resort to hackin this one up to get to those screws
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 08-15-2005, 07:37 PM   #2
matthufham
i was scratching my head over this the other day. eventually i put the screw driver in, hit the end with a hammer, put the adjustable pliars on the screw driver handle pushed as hard as i could in with one hand and turnd the pliars left with the other hand. eventually it broke loose and i was able to use that method 3 more times on other window screws that were philips.
matthufham is offline   Reply With Quote
Old 08-15-2005, 07:41 PM   #3
lowrider79
Try to tighten them first, it helps break them loose
lowrider79 is offline   Reply With Quote
Old 08-15-2005, 08:07 PM   #4
screamin_c102
screamin_c102's Avatar
Both of thes methods work well.
screamin_c102 is offline   Reply With Quote
Old 08-15-2005, 08:18 PM   #5
Frizzle Fry
Frizzle Fry's Avatar
If all else fails, drill the screws out CAREFULLY.
Frizzle Fry is offline   Reply With Quote
Old 08-15-2005, 08:18 PM   #6
junkyarddog67
Stuck screws
Have you tried an impact screwdriver? It is a great help in removing rusted and stuck screws.
junkyarddog67 is offline   Reply With Quote
Old 08-15-2005, 08:24 PM   #7
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
I used a #3 phillips screwdriver and hit the end of it with a hammer a couple times and it worked on all four in my '70.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 08-15-2005, 08:44 PM   #8
70 shorty
Where's my beer?
70 shorty's Avatar
I third the hitting the screwdriver with the hammer idea. My buddies dad told me that trick many years ago, and I use it all the time.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 08-15-2005, 09:05 PM   #9
junkyarddog67
impact screwdriver
I didn't mean to use just a screwdriver and hammer. This is an impact screwdriver. You hit the end of it with a hammer while holding it on the screw. It applies downward pressure while applying torque as well. They can't be beat for removing stuck screws.
Old 08-15-2005, 10:20 PM   #10
matthufham
i did a couple more in the door today, why they use philips i don't know. this time i used a vice grip on the pliars, and that worked for 3/4 of em, and i had to weld a nut onto one but i guess you can't do that for the armrest. also you can't get an impact screwdriver in the armrest hole, or can you, i have the 72 style.
Old 08-16-2005, 07:30 AM   #11
junkyarddog67
Impact Screwdriver
The black piece on the end that holds the bit comes off. You can insert an extension, just like on a ratchet. Your local auto parts store should have one. Check it out, they are a great thing to have. You will wonder how you got along without one.
Old 08-16-2005, 01:19 PM   #12
mrein3
mrein3's Avatar
I have a Snap-On, ratcheting screwdriver. I usually get that out when the gorillas with the impact screwdriver are done making noise.
The ratcheting part has nothing to do with the effectivness of the tool. It has a big handle which allows you to put a lot of torque on the stuck screw.
The other nice thing about this tool is that the bits are replaceable. A fresh bit of the correct size, coupled with the big handle, allow me to remove all screws that are "stuck".
And it came with a pack of almost naked lady cards. But then again what Snap-On tool doesn't. Just think how cheap their stuff would cost if they didn't have to pay for all those models.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 08-16-2005, 06:39 PM   #13
71-longbed
71-longbed's Avatar
i haven't had any luck ... probaly going to have to drill them out ... i rounded over acouple pair of screwdrivers using channel locks for more torque
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Old 12-11-2005, 03:56 PM   #14
71-longbed
71-longbed's Avatar
Re: arm rest help
what size drill bit should i use to get rid of these armrest screws ??
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Old 12-11-2005, 07:52 PM   #15
Re: arm rest help
Probably a 1/8" bit, but you'd have to be REALLY careful!
RJD
Old 12-11-2005, 07:57 PM   #16
mrein3
mrein3's Avatar
Re: arm rest help
Go to google and type in "left hand drill bit".
Pick one from a place you trust.
Nine times out of ten the left handed bit "catches" and turns the screw out for you. Then all you have to do is chase the threads and oil them up good before you replace the screws.
For size pick the size you need for your favorite extractor. If you end up NOT turning the screw out and you need an extractor you're half way home.
'72 Malibu hard top
Center City, MN
Old 12-12-2005, 03:49 AM   #17
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Re: arm rest help
When Bustem and the impact driver don't work (or the other good methods mentioned) since they are really rusted, you can cut them with a hacksaw blade between the arm rest and the door panel. Be very careful...but I have found if they are that rusted the door panel is probably shot too so what the heck. Just use a new blade and lots of WD40 and you can saw the bolt in half. I have done this several times with success. Good luck!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
