Difference in rear end widths?
Something way back in the corner of my mind says that '67-mid '69 have a narrower rear than a late '69-72. What are the widths? Am I right on this or have I been eating retard sandwiches again?
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
![]() ![]() Join Date: Jan 2005
If I remember correctly, they switched from the short to the long in the middle of the '70 model year. I guess that means they only made the 6-lug long axle for half a year?
its all about the +6 inches
that is correct, (mid '70) but I can't remember the widths. I think it was 3/8 on each side wider.
Retard sandwich...LOL! |
![]() Join Date: Aug 2003
Widths
I think 1 is around 55 1/2" and the other 57". That's from backing plate to backing plate.
On a related topic, where might a fella find a set of 5 lug axels for the narrower rear end? I seem to be having a problem getting ahold of a set. Any help is appreciated.
Thanks, Dan
Good Judgment comes from experience. Most experience comes from bad judgment. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Early Classics sells the 5 lug conversion axles for the earlier rear ends.
Hey, Thanks. Gonna have to check them out.
I Took Long Axles Out Of A 72 And Put In My 68. They Seem To Fit Fine. Were They Not Supposed To? But The 68 Axles Were To Short For The 72.
well, if the 68 axles are too short for the 72 rear.... how can the 72 axles fin in the 68 rear?
![]() I think i know what you did though, you grabbed some 5 lug drums from a 73 - 87 trucks, which is just wide enough...that or your brake shoes aren't in the drums all the way. If it is the former, that's a bad idea becouse the portion of the axle that is intended to ride on the bearings is the only hardened part, and it NOT on the bearings in your older axle. That's just asking for a broken axle, and when they go, they can exit the vehicle all together, leaving you on the highway with only 3 tires mounted. If it is the latter, well, I think it is obviouse what the drawbacks are there. You need to look at your rear...before somethign bad happens. |
#10 | |
For every person with a spark of genius, There are a hundred with ignition trouble. ![]() |
#11 | |
then I'd bet a punch in the gut that your shoes aren't tucked into your drums all the way and you are rolling on an non hardened portion of the axles.
#13 |
i double checked. you are right longhorn. i did not realize that when i put them in. i havent drove it, so no harm done. what options do i have now?
#14 |
swap out the whole rear, or get shorter axles.
#15 |
blood type; Retumbo
and strengthen up your abs. next time Andy see you, you are getting a punch in the gut.
since I just found out about this & I also recently got a '67 (6 lug one legger) I talked to my machine shop. he said for $60 he could re-drill & machine the center for a 5 lug.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
#16 |
$60.00 is better than $280.00 for axles from ECE. thanks ill check with a shop here.
#17 |
The cool thing about betting a punch in the gut...no one ever does it.
