Tightwad
Exhaust Running Options/with 4/6 Drop??
What are the options on running exhaust with a 4/6 drop or any drop that allows you to exit out the rear of the truck? Would like to see any pics if possible....
Trying to figure out which drop to go with that will allow me to exit the exhaust out the rear or behind the tires on a coil spring truck. I have a 68 swb stepside. Was thinking about a 3/5 drop or a 4/6 drop... eric |
blood type; Retumbo
a pic is worth a thousand words. here's 2K
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
Here is what I'm doing. And, I finally got some $$$ together, so I purchased the Crossmember from ECE. Should be installed sometime during the 4th week of August.
http://67-72chevytrucks.com/vboard/s....php3?t=166129
'71 Chevy C-10 - Current '62 Imapla SS - Traded for my current '73 Nova Hatch - traded for ATC-350X '73 Chevelle Deluxe - First car (R.I.P) DEERFIELD, MA |
#4 | |
![]() Quote:
Here's how not to do it IMO-
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
#6 | |
Seasonal Poster
P.S. - anyone in Kelowna wanting exhaust done, go to Tom at Precision. ![]()
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW |
Questionable
Would it be possible to cut and reinforce a hole in the framerails for the exhaust to pass through if you wanted to lay frame in the future? I'm really wanting to keep my exhaust at the same level or higher than the frame on my truck.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
I thought about running side pipes, ala the early 70's vette.
#9 | |
my gas saver
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
Questionable
Right, but I'm literally talking about taking it through the framerail under the cab or before the tranny xmember. Get it to the outside of the frame that way, then pipe out in front of the wheels or carry it all the way back.
Tightwad
I have cut holes in the x- meber before on a lwb 72 , worked greatand went over the axle good, but also the truck was not lowered. The one i am building now is a swb step side and i am wanting to lower it. I was thinking of cutting the x-member again and and weld stiffener plates on the x-member. But here is the real thing with me wanting to lower it and move tank to rear that does not leave much room to clear the rear axle. I would like to have my exhaust dump out the rear of the truck or each corner of the fenders with just alittle bit of chrome tip showing, but i guess i am wanting to much and not enough rooom....lol. I was looking for ideas on how some of yall ran yours after the drop . Was thinking about a 4/6 drop or 3/5.... I have good ideas how but just wanted to see what everyone else did. When i do run mine i will take good detail pics so it maybe could get posted in faq....I know there wil be more wondering how or might be the best way and pics can save many many words....
eric Last edited by Chevy_Man; 08-17-2005 at 01:11 PM. |
#12 | |
#13 | |
my gas saver
#14 |
-Praise the Lowered-
Here's a write-up on my installation. My truck has a 3/5 drop. May not be exactly what your lookin' for. Thought I would add it to your list of options....
Note that I didn't run the pipes between the frame rails, and I still have plenty of ground clearance (IMO) for a cruiser. http://67-72chevytrucks.com/vboard/s....php3?t=127448
Race-N-Jason ('71 Chevy C-10 LWB 454/TH350) ('07 Dodge Ram 2500, 5.9 Cummins/6-speed Manual) |
#15 |
![]() Join Date: Jan 2002
I have seen it done before. The guy took a short piece of 3 inch schedule 40 pipe and cut an eliptical hole ( so the exhaust runs through at an angle) and welded the pipe in at the correct angle. I think if you boxed the frame right there it would look pretty good
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
#16 |
On the road
![]() ![]() Join Date: Jan 2004
Eric,
Here are some pics of mine as I promised you. I just got this system installed this past weekend. I have a big block with full length swap meet headers, I don't know who made them. They hang down pretty low but I have never drug them. The A-arms are as low as they are anyway. I did this "TXfirefighter style". I bought straight length's of 2 1/2" tubing from Summit along with Summit turbo's and Walker tailpipe spouts. I also used walker stainless clamps to connect the mufflers. I bought 45 degree elbows from JC Whitney that were expanded on one end, cut to fit and welded it all up. Everything is aluminized. It sounds good and has a nice rumble. I know a lot of guys like to run them on out but I like the pipes hidden. I think there is enough room to run them over the axle and on out from under the truck if I wanted to. I have a 4/6 drop and had them over the axle when I had my small block but only had 2" pipe then. Mike
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
#17 |
Tightwad
Hey Mike, that looks good not a bad job at all thanks for posting, that goes to show the guys you don't have to be a muffler man to run your on pipes and have a good clean set up at a low price. I thought about that too just till i can get the truck back together then see how much room i will have after i got the weight back on here and see how she sets and sounds.
eric |
#18 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
It's a pain to do it, but it rocks when you can tell everyone you built it yourself, down to every last nut and bolt, and even exhaust pipe.
#19 |
On the road
Amen TX. LOL there are worse things you could be named after, you were my inspiration when I built this system.
Mike
#20 |
Member since 2000
The way GSFMECH has it is the way I have mine......I also have a 4/6 ECE kit.
#21 |
laying low
![]() Join Date: Mar 2001
Anybody have an under side pic of a factory stock dual setup? Just how is it routed?
Reason I ask is I am considering buying some stock pipes for temporary runnin.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
