Which Carb would you recommend?
I'm replacing my 2 barrel with a 4 on my 350 with factory air. Which carb would give me adequate power and decent mileage?
Someone recommended Edlebrock 1406! I have a stock 4b intake manifold or should I get a new one of those too? |
I've used Holley and Edelbrock. The holley was fussy and needed attention quite often. The 1406 Edelbrock just bolts on and with minor adjustments runs great. Down here they say Holleys are for working on and Edelbrocks are for driving. I'd use a Holley for racing but an Edelbrock for my cruiser. Got a 1406 on my truck right now.
I just put an edelbrock performer intake and 600 cfm matching carb on my stock 350. It works great. super response and no maintenance. Total cost around $500. has electric choke. no regrets. I agree with last post about holley.
Rivernut
'72 1/2 ton 350 auto |
#4 | |
Thats the Hillbilly way
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
![]() Join Date: Feb 2004
I am running a 1406 Edelbrock also
Nobody rides free
![]() Join Date: May 2005
+2 for me too.
'71 C10 LWB 400SB/350TH ![]() '86 K2O LWB 350SB/400TH-6" tuff country lift, Shackle flip - plow truck '06 HHR - wifes wheels '01 Blazer - daily driver "It's better to burn out than it is to rust." -Neil Young |
![]() Join Date: May 2004
Edelbrock 1406 (is there an echo in here?) Love mine. Easy to tinker with but more often than not, you don't have to. The Edelbrock tech support is very good too!
CARTER AFB or EDELBROCK (same carb w/ different name tags) i will NEVER EVER EVER EVER EVER use a quadrajunk again and what the others said about holley is 100% correct. (i used to be a big holly guy till i used the CARTER)
Senior Moment
![]() Join Date: Mar 2002
I still like the Holley for both street and strip. I will say the Edelbrock out of the box works great for a guy with little carb experiance, but I get better performance from my Holley.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
![]() Join Date: Aug 2005
Holley on my DD. No issues...
I went through two Road Demon carbs before giving up and getting a 1406. Zonaman's right. Echo, echo.... ec...
Oh, forgot to mention if you buy from Checkers there is a $25 mail in rebate too.
#13 |
![]() ![]() Join Date: Jan 2005
I am extremely happy with my 1406. It takes about 5 minutes to change out the metering rods, and maybe 20 minutes to change out the jets. No blown out power valves to replace. No leaky fuel bowl gaskets. No funny little accelerator pump cams to play around with.
If you go this route, make sure you install a fuel pressure regulator. |
#14 |
How do they compare in price?
Summit: Ed 1406, $265.95; Ed Performer EPS, 2701, $129.88
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. Last edited by tomatocity; 08-16-2005 at 05:12 PM. Reason: text |
#15 |
No,I DON'T have Tourett's
2 more votes for 1406's
'72 K5 CST 350/350 Daily Driver '69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck '69 GMC 2500 L6292, 3spd beater |
#16 |
Thanks for the info guys, It looks like 1406 will be my choice.
Do I need to buy an intake also or will my original intake that came with a 4barrel quadracrap work? |
#17 |
You will need a square bore intake manifold.
#18 | |
I got my 1406 for $275.99 plus $25 rebate = $250.99 |
#19 |
Howdy;
I scored my 1406 from a guy who wanted a bigger Holley - saved around $100 . Got a used Performer intake from another board member, likewise saved around $50-$75 off retail (web or otherwise). No worries. cowboy33713 P.S. to gator- nice truck! |
#20 | |||
Union Electrician
600 cfm holley on my truck....9MPG, after putting on a 1406 edelbrock jumped up to 14MPG with no other mod, which is nice since gas is so high now, Randy
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
#21 |
Active Member
![]() Join Date: Dec 2002
Location: West TN (Memphis area) now. East TN (my favorite place to live).
Eldbrock are good carbs. I just put one on my truck. But when I build a high HP/Nitrous motor next spring, I am going back to Holley.
BigFredTN 70 chevy stepside 350 with some goodies inside, turbo 400. 69 Chevy long wheel base. Dad bought new in 1970 62 Chevy Impala 98 GMC Yukon 1970 Ford Mustang Fastback I know its a Ford. |
#22 |
Wow I guess I will be the bummer. I hate My 1406. The choke is horrible. Up here if it's -20 and you have the choke set when it was -5 the choke will not come off. Then when it warms up a bit the choke will not come on. NEVER did I have that problem with the so called "Quadra junk" The 1406 are horrible to start after the truck has been sitting for a couple of weeks. I just dont like them. M.H.O
I would love get a Original GM Quadrajet.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#23 |
If you are looking for a Q-jet contact Cliff @ Cliffsqjet.com. He builds alot of q-jets and has cores if you need one. He will spend the time to build one exactly the way you need it.
#24 | |
#25 |
Go with a quadrajet, you shouldn't have any problems with 'em if they're built right.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
