Old 08-16-2005, 01:50 PM   #1
PHOENIX
Q-Jet to Performer Carb (1406?)
I am thinking about switching carbs.
I have an Edelbrock Q-Jet 1904 now.
I planned to get it rebuilt, because I don't want to try it myself, and the lowest price I got from someone I think I can trust is $150.00.
So I figure maybe I should switch to the Edelbrock Performer 1406.
Is the 1406 the one I should be getting if I do make the switch?
Its either the Edelbrock Q-Jet rebuilt or an Edelbrock Performer series, not interested in others.
I have the Edelbrock 3701 intake. Is this also a sq. bore pattern?
Will I notice a performance difference between the q-jet and the Edelbrock performer?
Anyone make the switch and noticed less power?
Are these performer carbs easy to rebuilt and adjust?
I want something easier to adjust and easy to rebuild.
Will I be able to hook up all my vacuum lines for emissions?
Anyone in Phoenix running this carb and have trouble with emissions?
I heard before that you may fail for having this carb on a truck that came with a q-jet.
Edelbrock's website says this carb is not legal for pollution controlled vehicles.
Anything I should expect (different parts, etc.) if I do make the switch?
My engine is the standard crate 350 (not performance).
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 08-16-2005, 05:51 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I am pretty sure gchemist has one of those on his truck. He might be able to make a comparison for you. I have not used one, but I have never heard anything but good stuff about them. They go for about $270 around here in the parts stores, so the prce is really tempting.
Let me know if you want to sell your 1904.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 08-16-2005, 05:55 PM   #3
PHOENIX
I think I will probably get the q-jet rebuilt.
I don't want any issues when emissions rolls around.
Old 08-16-2005, 06:03 PM   #4
bigarmzz
bigarmzz's Avatar
i've had several edelbrock performer series carbs....very easy to adjust and install....
i've found them to be maintanence free as well
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 08-16-2005, 06:03 PM   #5
72MARIO
72MARIO's Avatar
Get the Q jet rebuilt. I hate thoes 1406's.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 08-16-2005, 06:04 PM   #6
PHOENIX
Tell me why you hate them.
Old 08-16-2005, 07:00 PM   #7
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
My 1406 isnt to bad it seems to have more power but its uses more gas. It works okay but I rather have my m4me.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 08-17-2005, 11:15 AM   #8
PHOENIX
I decided to stick with the Q-Jet, its been good to me and I am
happy with the performance of the truck (for what I have).
I took it down to get rebuilt, should get it back today.
Hopefully have it back in the truck and running by Saturday.
Old 08-17-2005, 11:07 PM   #9
ureckme
ureckmefixit2@cox.net
I have some friends that have an A/C and mechanic shop in gilbert, and they run the Edel 1406 on sbc they swear by them. I stop by there every day after work and BS around. These guys give me alot of cr@p becouse they think a I'm Holley only kinda guy. Well I'm not, I just know holleys better than I know the other carbs. I have run AVS, AFB, Thermoquads, Q-jets. I have all ways come back to Holley's. 2 months ago I rebuilt an Edelbrock Q jet for my brother in laws room mate, It working perfectly and it's on a 350 sb, and I charged him $35.00. I havent heard any complaints. As for Holleys I run a 750 vac secondary 268H comp cam 10.5 to 1 compression and pass emissions with a .128 on HC, Max allowed is .400 on HC and my truck was shaking the building at the emissions station. Matt
That's U RECK ME FIX it 2
74 Chevy Short Bed
355ci Sportsman II 64cc Angle Plug
Crower Custom Grind .462in .486ex
Dyno Test 422hp @ 5600
And it's got a Holley
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
I'm a Body Man So There!
That's why it's not painted
ureckme is offline   Reply With Quote
Old 08-17-2005, 11:31 PM   #10
72MARIO
72MARIO's Avatar
The choke setups on the 1406 are horrible. Nothing like your trusty Q jet. Then you are forking out money on a carb that's really no better than what you have right now. I bought a 1406 for my 84 C 20 everyone said they go right out of the box, Well the go bang bang thru the carb cause it's way to lean so right off the batt. I need a $100.00 jet kit to get my $450.00 carb to run right. See why I hate them I have over 550.00 into a carb that needs th echoke to be readjusted every couple of weeks because the weather tepm bounces 15c. My dad and I both bought them at the same time. Both of us wish we would have left them on the shelf.
JUST M.O Sounds like you made a good decision.
All prices acre CDN.
2005 TAHOE DD
Old 08-18-2005, 11:16 AM   #11
PHOENIX
I paid $135 to have it rebuilt. Most of it was labor.
The guy I had rebuild it seems like a fair man who has been doing it for awhile.
His typical rebuild cost for a q-jet is $155, but I already had a new float, and most parts were OK so he reused them and took it off the $155.
The plugs on the bottom that can leak are not sealed up any different on these Edelbrocks then the older Rochesters. He sealed them up with epoxy or what ever they use. He also drilled out the shaft holes and installed oil impregnated bushings. He says when a carb is in good shape like this one its good to have it done. Keeps everything in line better and can make the carb last awhile longer. He also said the accelerator pump in mine wasn't working as well as it should. He said the fuel blend we get here eats up these stock type ones. He installed "the blue one" which is much better and should easily last 3-4 years without problems. Don't have it on the truck yet, but I feel confident in his work, Ill let you guys know how everything is doing once I get the truck on the road, hopefully by Saturday.
Old 08-18-2005, 07:17 PM   #12
wedgemon
wedgemon's Avatar
Cool 1406
I've don this with a stock Q-Jet to the 1406.
- Yes! Sounds better and Performs better - comparatively. BUT, Check the jetting charts for your altitude. They're benched for sea level and I'm at 4800 feet. You can get the approprate jets for about $9 bucks from Summit.
- I got more power and better throttle. Be carefule with linkage though.
- Haven't needed rebuild yet.
I want something easier to adjust and easy to rebuild. Will I be able to hook up all my vacuum lines for emissions?
- No problems. Above & below throttle connections and booster.
- Not sure there. No probs here in Reno.
- Same engine as me. You may need to go with the EGR model (1407??)
Anyway, I dig my Edelbrock. And it looks great! Not that that helps with performance or emissions.
-Dave
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 08-19-2005, 07:25 AM   #13
MylilBowTie
Right turn Clyde
1407 Is a 750 Edelbrock, and the funny thing with those is they dump gas and the basic 1406 is pretty lean for most engines outta the box. Side note the manual operated choke models run a tad richer than the electronic choke ones.
1406 isn't that bad and they can be messed with to get right, just like any other carb. But I just like the Quadrajet myself, I even though I have a 1406 on mine right now. I need to fix the quadrajet to get the 4 barrel working right. Sucks on the highway with 2 small barrels and trying to pass someone.
