Old 08-16-2005, 07:59 PM   #1
alf1096
alf1096's Avatar
Rust
I will be going to look at a 72 swb this week end and was wondering where should I look for rust where is it usually at in these trucks
alf1096 is offline   Reply With Quote
Old 08-16-2005, 08:02 PM   #2
Joe67
67 is sold
Check the braces where the cab mounts to the frame.
Check the frame perches where the cab mount bushings mount.
Check the rocker panels (inner and outer)
Check the rear cab corners
check the floors, especially where they meet the kick panels on either side in front of the doors
Good Luck
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 08-16-2005, 08:11 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if it is a true tx truck, you don't have too much to worry about.. onless it is from eastern or costal areas.
Tx rust is typicly found in the cab corners, rockers, some times cab mounts, bed floors and lower front passenger fender.
Anything more and walk away since these things are a dime a dozen down there.
Pick up a thriftey nickle, and you'll find 5 minimum every week.
Last edited by Longhorn Man; 08-16-2005 at 08:11 PM. Reason: The voices told me to
Old 08-16-2005, 08:28 PM   #4
alf1096
alf1096's Avatar
If they are a dime a dozen I am having a hard time finding any. Where do you look I am Located in north Texas and have an truck trader and there were only 5 trucks I need one that runs and is about 5k if I can find it
thanks
Old 08-16-2005, 08:29 PM   #5
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Also look for rust around the top of the windshield and the roof! My truck has been here in Texas since it was new and it had a lot of rot around the roof area. Not sure how that happened though.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 08-16-2005, 09:06 PM   #6
Longhorn Man
Robert...thanks for saying something on that. That IS another common area. The heat dries up the sealant on the cab roof at the drip rail, it cracks, and water gets in there and puddles over the windshield.
Alf, granted, it has been a few years since I was there, but these rigs were EVERYWHERE down there. Come up here and you'll be liucky to find one in the paper a month. And odds are it is a total rust bucket and they still want top dollar.
And for 5 grand, you should be able to find a pretty nice ride.
Old 08-16-2005, 09:17 PM   #7
cdowns
cdowns's Avatar
go to major swapmeets in your area you'll probablly see 50-100 for sale in a day just in the parking lots alone
www.hemmings.com go to their events section lookup states near you
Old 08-16-2005, 10:15 PM   #8
wolfthing2000
Exclamation
Just to add to the list:
Rear of fenders at lower corner, stuff piles up down there and water can't drain. Also under the battery at the front corner is usualy a bad place for the above reason and bat acid. My truck has a little of about all of this and fortunately I found a new front clip from a 68 for the 69 truck that is very sound!! Cures the rust issue and a much more desirable front end look! ( my opinion).
I have found a slight amount at one corner of the rear window seal, lower right outside where there is a split in the seal.
Also this truck had/ has what could pass for a bird's nest or more likely a small beaver den in the bottom of the air vents from stuff coming down through the cowl??? I assume????
Another spot is hard to find, but in the seams along under the bed bottom to the sides.
The Rockers looked real good on mine when I purchased, however after removing carpet there is a rust concentration area between the seams of the rocker top where it overlays the floor at the door seal area. This rust will start under at the seam and creap along this area taking out the top of the rocker and the adjacent floor area.
Just things to look for and dicker over when ya go shopping.
wolfthing2000 is offline   Reply With Quote
Old 08-16-2005, 11:54 PM   #9
jimfulco
Also, check the ledge on the firewall below where the back of the hood goes.
jimfulco is offline   Reply With Quote
