Old 08-16-2005, 08:53 PM   #1
harleyd_1903
lowering rear with springs?
How hard is it to lower a 71 c10 with rear coil springs? and how can it be done ?
harleyd_1903 is offline   Reply With Quote
Old 08-16-2005, 09:05 PM   #2
LONGHAIR
Sure........shorter coils. You can also lower an inch or two with a block between the axle and the trailing arm.....but the coils are the more common "kit" approach.
LONGHAIR is offline   Reply With Quote
Old 08-28-2005, 07:49 PM   #3
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
can someone point me in the right direction as to who sells the blocks? Are they standard blocks like the ones you get at any auto parts store? Just need the blocks and longer u-bolts right?
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 08-28-2005, 08:15 PM   #4
matthufham
and a deep 1 1/16" socket or so, i didn't have any sockets that large that were deep so i left it on when i painted the frame and the rear end.
matthufham is offline   Reply With Quote
Old 08-29-2005, 09:51 AM   #5
Joe67
67 is sold
Just use an open end wrench to get them loose and take them off by hand
You can replace the rear springs in a very short time
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 08-29-2005, 09:47 PM   #6
matthufham
not the U-Bolts, the only wrench i have that big is a monkey wrench. the springs come out with a 3/4 wrench though. it's an easy removal as long as the bottom cup stays in place. take the top mount off first, then you can pull the spring while removing the bottom cup and it won't spin if you put pressure on it.
