Old 08-17-2005, 02:33 PM   #1
ScottH
ScottH's Avatar
How to replace door hinge spring?
Can anyone tell me how to replace the door hinge spring (keeps door open) on a 1976 C10 door?
Any help is appreciated.
Thanks.
ScottH is offline   Reply With Quote
Old 08-17-2005, 03:31 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I have a broken spring as well on my driver's door. I have seen discussion in the past where one person said he was able to install a spring with the door on the truck using a long screwdriver. I have not been able to do it with the hinge in place. Everyone else I have seen discuss it said the spring must be installed with the hinge off the truck.
I hope someone has a nice solution.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 08-18-2005, 09:53 PM   #3
mbgmike
I just hold up the door (I have a door lift but you can improvise) take off the door and hinge and replace it. it doesn't take very long. I've never been able to get it in w/o removing it.
mbgmike is offline   Reply With Quote
Old 08-18-2005, 10:15 PM   #4
ureckme
ureckmefixit2@cox.net
I have, but its hard to put in words. Put in spring, use big bent screw driver to twist spring and hammer in to place. Matt
That's U RECK ME FIX it 2
74 Chevy Short Bed
355ci Sportsman II 64cc Angle Plug
Crower Custom Grind .462in .486ex
Dyno Test 422hp @ 5600
And it's got a Holley
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
I'm a Body Man So There!
That's why it's not painted
ureckme is offline   Reply With Quote
Old 08-19-2005, 02:31 AM   #5
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
I changed just the S shaped spring with the door still on the truck. Open the door all the way and put the S spring into the top slot first, with it slid as far down as it will go. Then make sure its lined up in the middle slot in the hinge. Then, using the door, start to close it slightly. You will see where the stock "little wheels" will push on the bottom part of the S spring. Close the door enough to where the S spring is lined up with the bottom slot. Use a small hammer and lightly tap it till it seats in the bottom slot.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 08-19-2005, 09:06 AM   #6
ScottH
ScottH's Avatar
Thanks to all, I'll have to give this a try.
Old 08-19-2005, 10:06 PM   #7
82 Silverado 4X
Genuine Chevrolet
82 Silverado 4X's Avatar
They also make a tool that compreses the spring. Works really slick.
George
82 Silverado LWB 4x4 350 SM465 NP208
77 Chevrolet Blazer Chalet 400 TH350 NP203
82 Silverado 4X is offline   Reply With Quote
Old 11-06-2017, 04:52 PM   #8
truckin 79
Re: How to replace door hinge spring?
I know this is old but just wanted to say this was a great thread. I installed S clip on drivers door by using this method. I used a hybrid of ureckme and justins76 method. I just put spring in and then used a big pry bar until I could close door and the first little wheel pushed into spring. I no longer needed the pry bar after that just a small hammer. I pushed door closed just a little more and the bottom of S spring hammered into place effortlessly.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 11-07-2017, 09:28 AM   #9
Rich84
Rich84's Avatar
I have to try this..My passenger side spring broke about 4 years ago. The door hits my wife all the time because she still expects it to stay open.
Rich84 is offline   Reply With Quote
Old 11-07-2017, 02:00 PM   #10
abig84
abig84's Avatar
i dont think i ever did one on a full size but for the s10s they sell a tool. but before i used the tool i used to put the springs in a vise but left a little bit sticking out so i could run some thin wire through ti to keep it compressed, stuck the spring in and cut the wire. thankfully i never lost a eye doing it that way
abig84 is offline   Reply With Quote
Old 11-17-2017, 04:50 AM   #11
Man With A Gun
Man With A Gun's Avatar
Going to try this tomorrow. Thanks
77 Chevy K20 Longbed
86 GMC C3500 Dually
07 Silverado 2500HD
All standard cabs
Man With A Gun is offline   Reply With Quote
Old 11-17-2017, 09:10 AM   #12
notallthere
This is the tool that I bought to do the job.
https://www.amazon.com/AES-Industrie...70_&dpSrc=srch
notallthere is offline   Reply With Quote
Old 11-18-2017, 04:17 AM   #13
Man With A Gun
I did it with just a flatbar.
Worked like a champ.
86 GMC C3500 Dually
07 Silverado 2500HD
All standard cabs
Old 11-24-2017, 11:40 PM   #14
Super_Dave
Super_Dave's Avatar
Forget the spring. Time to change wives, if'n after four years she ain't figgered out the door taint gonna stay open!
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair
"Life is tough - wear a cup!"
"Old Enough to Know Better - Too Young to Resist"
"Junk is something you will need three weeks after you throw it away."
Super_Dave is offline   Reply With Quote
