I just swaped to a new alt. I no longer have the over charging problem.
I bought new headlights installed them and Now I only have high beams I hit the brand new floor switch to low and I can hear the the light switch in the dash clicking. What is wrong do I need a new switch also ? Anyone have any suggestions ? Thanks,
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Did you change your regulator or your alternator ? I had the exact problem, new regulator fixed the problem. make sure your connections to the light are good, make sure you have a ground well grounded. Check to see if you have power to the headlights.
Good luck
67- 72 Parts collecter |
Having issues
Mebbe the floor switch is bad? Disconnect the plug from it and use a ohm meter to check for continuity. Click it and see if its any good.
Quando Omni Flunkus Moritati. The Man's Prayer: "I'm a man, but I can change, if I have to, I guess." |
Ummmm I am super Dumb.
When I attached the broken ground wire back to the fender I pinched the low beam wire gounding it to the frame also. Opps. Thanks for the help.
That clicking in the light switch is actually a circuit breaker. If there's an overload or a short, it shuts off the power to the lights.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
