Old 08-17-2005, 04:44 PM   #1
chevyjr73
chevyjr73's Avatar
t350c extension housing?
does anyone know what is involved in removing the extension housing on a t350c transmission? my transmission shifts fine but there is a loud ticking noise coming from inside the area of the extension housing with every revolution of the driveshaft. what inside could be causing this? thanks.
chevyjr73 is offline   Reply With Quote
Old 08-17-2005, 06:19 PM   #2
red86chevy
to the best of my knowledge all that is in there is the speedometer gears. (plastic) and a little metal collar that will keep fluid from running out when you park on an incline.
86 c-10 383 w/ sportsman II heads comp 286h cam Edlbrock RPM Performer intake Holley 750 th350 w/2400 stall 3.73 gears with powertrax No-Slip posi unit. Just broken in good. Will get a 1/4 time this week.
red86chevy is offline   Reply With Quote
Old 08-17-2005, 06:29 PM   #3
chevyjr73
chevyjr73's Avatar
sounds like i can remove it then. thanks
Old 08-18-2005, 09:16 AM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
There is an o-ring under the housing. When I pulled mine off, none of the parts stores could look up the part. The dealer had no problem.
I would check the gear before you pull the housing off. There really isn't anything else I can think of inside the housing that could make noise. There is a small metric bolt that holds a tab that keeps the "bullet" in. Remove the bolt, and the bullet and the speedo gear will pull right out so you can check them.
If it leaks at the cable at all, the parts are surprisingly cheap to replace. A new bullet with new seal and o-ring installed and a replacement speedo gear cost me less than $6. Make sure you get the right speedo gear for your axle ratio. The folks at the shop told me they have a different color for each number of teeth, and you can just match it up by color.
Here are my parts, and what I paid for them.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 08-18-2005, 10:30 AM   #5
60-66 Nut
Professional Beer Tester
You might be hearing the weights on the governor clicking. The governor is located under the round cover at the rear of the trans on the left side. If you want to check it, just pop the cover off and the governor comes right out. Then you can see if you still hear the noise. Just a thought. Good luck.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
