body drop
Has anyone done a body drop on these trucks before and I dont mean putting in smaller body mounts. I am looking to drop the body 3" because I want to cut the rocker off and lay door. I think I may just end up cutting the section out of the floor so the frame can come up into the cab. The frame will stick up about 2" in the front and 1" in the back. Plus I would have to cut a section for the trailing arm crossmember. what do you guys think?
66 C10 (under construction) 1.5" crossmember drop 2" Z'ed frame 8" rear notch Watts-link Bagged DJM 3" spindles |
crazy
65 c10 tore apart 70 c10 305/350th |
![]() Join Date: Aug 2005
I set the height of the body relative to the frame on my '61 where I wanted it. So you could call it a body drop, but I didn't use the original frame. I've seen a site where a guy did a standard body drop that involved floor and frame modification.
IMHO laying door looks like garbage, but it's your truck. Anything can be doneā¦ |
Happy to be here
![]() Join Date: Mar 2000
This is as close as I can get....
///Relaxed Atmosphere
NTRUX: updated pics of that truck
HEre are soem, updatedpics of that truck I ran into a while back. The entire body was reskinned by Grant Custem MEtal Fab. All Chassis work was done by IF Customs in Cali.
I have seen it in person and it is insane in bare metal. Jeff
72 Suburban 64 Chevy short fleet 04 Chevy Colorado Sport Reg Cab 2012 Chevy Avalanche 2003 Chevy S10 Blazer Xtreme http://www.hubgarage.com/mygarage/RA_Jeff 64 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=295915 |
I've seen that thing in a mag recently. Just a small pic of a show they covered. That is some f'n amazing sculpting! It has part of a 67-68 hood! So does it "lay door"? On cars/trucks that lay door, how do you get in and out? Remote airbags? Lambo Doors? It's not my thing, but obviously has a following.
Rockers1/2"off the ground
I did a 2.5" bodydrop!
1962 fleetside: bodydropped,shaved,bagged,custom 64 suspension,clear taillights,custom aluminum parts,rollin on 100 spoke player wire wheels. http://www.finelinedesignz.ca |
#8 | |
