Old 08-17-2005, 05:30 PM   #1
tomatocity
tomatocity's Avatar
Clear coat Intake manifold
Can there be a problem with clear coating an aluminum intake manifold? I have heard that some clear coats can yellow. I plan on bead blasting the intake manifold whether I clear coat it or not but I wanted to hear the opinions of the Board members.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 08-17-2005, 05:41 PM   #2
HeavyD
HeavyD's Avatar
I had one yellow, but that was back in the 80's..maybe clears are tougher now?
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 08-17-2005, 06:07 PM   #3
cowboy33713
Howdy;
If you block the heat crossover (if your truck will tolerate the "cold" intake set up,not a problem here in Florida), yellowing or even paint burning off won't be a problem. I used VHT brand clear, which they rate as clear engine enamel.
Felpro has an intake gasket set with metal block-off plates at the heat riser for those wishing to do the block off thing. Used to have the part number, but need to look it up again myself. If you use composite gaskets w/o the plate (and your heads and intake have the heat passages) the gasket will burn through there in short order.
cowboy33713
cowboy33713 is offline   Reply With Quote
Old 08-17-2005, 06:42 PM   #4
cdowns
cdowns's Avatar
for a long term one time application i prefer powder or ceramic coating
Old 08-17-2005, 06:47 PM   #5
tomatocity
tomatocity's Avatar
Good idea but I will not be keeping this manifold so I want a less expensive method.
Old 08-17-2005, 10:15 PM   #6
ed455
Captain Ed
Originally Posted by cowboy33713
Howdy;
cowboy33713
Those metal blockoff plates burn through pretty quickly.
If you ain't bleedin', you ain't workin'!
1999 C3500 LS 7.4L
ed455 is offline   Reply With Quote
Old 08-17-2005, 10:50 PM   #7
72MARIO
72MARIO's Avatar
I would not reccomend doing it. I cleared mine and I di dnot have the block off plated installed by the engine builder. Now my intake is yellow and burning where the heat crossover passages or what ever they are called.
I wish I would have left it raw at least it's cleanable.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 08-17-2005, 11:19 PM   #8
67_C-30
I have a radical idea!
67_C-30's Avatar
I had have much better luck with Duplicolor's Cast Aluminum Engine Paint. It has a metallic base (it probably is aluminum) and I have never had it turn yello. It doesn't really change the appearance of an aluminum intake, but it makes it much easier to keep clean.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 08-18-2005, 09:30 AM   #9
Brewski*
Brewski*'s Avatar
Don't Clear Coat The Intake~!
DON'T CLEAR COAT THE INTAKE~! I did my Edlebrock 2101 Performer with POR-15 Glisten PC which is the strongest hardest clear I have ever found. It yellowed bad near and around the cross over tube areas on both sides of the carb after about 1k miles. I did the valve covers and they still look fine (2 years) I just did the intake again with POR-15 chevy orange this past week. Looks INSANE nice.
Brew
Brewski* is offline   Reply With Quote
Old 08-18-2005, 11:04 PM   #10
masterbeavis
Having issues
masterbeavis's Avatar
I thougt I posted in this thread already, but I guess I didnt hit the post button. Oh well. I would not clear the manifold. Like previously stated, it will yellow. Ive seen some clears turn soft when they get hot, and crap will stick to them. Paint it your color of silver, and call it good. Espeicially if you are not going to keep it.
Quando Omni Flunkus Moritati.
The Man's Prayer: "I'm a man, but I can change, if I have to, I guess."
masterbeavis is offline   Reply With Quote
Old 08-18-2005, 11:39 PM   #11
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
I haven't seen anything that will not burn off that center heat port, if it is not blocked, except ceramacoat. Powder coat will burn off. I still powder coat some of them silver and them reshoot the center port with silver header paint, after it burns off. Not too bad.
The concours vette guys ceramacoat their intakes and then paint over the top. They say the paint then won't burn off. $$$$$$$$$$$$$$
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 08-19-2005, 12:35 AM   #12
Green Machine
Green Machine's Avatar
I used Eastwoods exhaust manifold paint on my cast iron intake, hasn't burned a bit or turned color, and looks like an aluminum intake too. Don't know if that paint will work over aluminum though. My crossover passages are open, not blocked.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
