King of Rust
Ok, so my PO changed from a manual trans to auto and installed a new steering column.
Question is, should the steering wheel and trans shifter lock when the ignition is turned off?? As it is right now you can jump in the truck and put it in neutral and steer it off to criminal land. Any thoughts/help?? 1970 GMC w/TH400. Last edited by KAILUAZ; 08-17-2005 at 06:02 PM. |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Stock auto column does NOT lock.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
![]() ![]() Join Date: Jan 2005
I put a club on my steering wheel when I leave it in places like airport parking lots.
clubs can be taken off by a pro in about 2 seconds. my auto column doesn't lock, and my floorshifter has no neutral safety switch so i can shift without a key or braking.
its all about the +6 inches
yep...pretty dern easy to steal.
If you're dealing with a professional thief, there really isn't anything you can do to stop him, right? Of course he will probably be looking for something that is worth a little more than my beat up old truck. Now some punk kid who knows how to hotwire an old vehicle and wants to take it for a joyride might consider it. Just my opinion.
As mentioned in a similar thread, may want to go with the removeable steering wheel.
CPO U.S. Navy(Ret) 1972 GMC Jimmy 4x4 Custom 1972 GMC Jimmy 2x4 Custom |
You don't even need to know how to hotwire... it's quicker to plug in an ignition switch that you carry with you.
Questionable
Removeable steering wheel? Any reputable theif will scope out the vehicle first and bring the parts they need the next visit. That may include a steering wheel.
My advice is to lower it so much that it's laying frame and it can't be towed, then make the pump inoperable. In addition to that, install an alarm, fuel kill and starter kill. Then add lojack. If anyone can get past all that crap, they deserve the damned truck.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#13 |
I have the grant steering wheel lock that removes the steering wheel and places a guard over where the steering wheel mounts. It uses a key to lock and unlock. It only takes a second to do this.
For every person with a spark of genius, There are a hundred with ignition trouble. ![]() |
#14 |
Install a floor starter out a 55 or 56.... That way you know the theif will have to be at least 45 yrs old to figure it out
#15 |
Epoxy Primer Friendly
like this lol ? read the license plate
#16 |
is there a monthly fee on lo-jack? if so how much? i am really considering this for my truck...
-Steve |
#17 | |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
#18 | |
Happy to be here
![]() Join Date: Mar 2000
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 08-18-2005 at 09:00 AM. |
#19 |
I had a friend that put a small switch behind the dash, under the ignition switch. It was wired so that unless it was engaged, the fuel pump, starter and ignition system would not work. He had it set up so that a magnet on his key ring stuck to the dash engaging the switch and allowing the car (67 Camaro) to start. I thought it was pretty slick.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates) 67 short step project (will get SWB from the 68) 67 Camaro, #'s matching (my wife's) 03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear |
#20 |
Still Green but learning
Its been said before, declared value insurance is the best deturant against theft. If you pay premium to have insurance for such things, then you know it will never happen.... I think murphy said something about this somewhere.
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
#21 | |
Mike
![]() As far as towing goes,You can not lower it far enough not to be towed.My winch is stronger than the friction of Your frame against the ground!So I destroy a $100 bumper.And Like John said,a car alarm going off will not make anyone look at a tow truck.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
#22 | |
LOW DOWN on LO-Jack
Nope, no monthly fee... just $750 or so and they will come and install in your driveway. I had one put in a vehicle of mine. Once installed you CANNOT remove it. It stays with that vehicle for life! They will not even let you see where they put it or observe the installation process. I thought I would get a discount on insurance but my company said NO. Most insurance companies act like they never heard of the damm thing... It's their way of playing dumb so they don't have to give you a discount on rates. http://www.lojack.com/index.cfm Last edited by Americanrider; 08-18-2005 at 01:35 PM. |
#23 |
Professional Grade
I made my own little theft deterrant system. I installed a small pushbutton killswitch in a place that very few people would ever consider, then went ahead and installed a bit silver toggle switch under the dash that any theif would think "Bingo" to and try and flip it. However, unbeknownst to them, when that switch is hit, it energizes a relay that stays in the on position that I hid in my fender that does not turn off if you turn the switch off. So the bugger will try and flick the switch off, or cut the wires to stop the blaring horns (they are rather loud, and this setup runs through a signal light flasher so the horns honk on and off like an alarm system). The only way to turn the relay off is to hit another switch I have hidden near by the relay which turns it off, and shuts the horns off.
However, again, its more of a deterrance that'll make people look as the horn starts blaring and the theif scrambles to shut it off. If they want to disable it, they can just pull the horn wires, but they will still need to figure out the hidden kill switch, and by that time, they probally will have given up, and if they do want it, they'll get the truck regardless ![]()
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) Last edited by Russell; 08-18-2005 at 01:56 PM. |
#24 | |
Listening since '86
2007 Saturn Aura - hey it WAS a GM product Last edited by JoetheMobster; 08-18-2005 at 02:05 PM. |
#25 | |
Listening since '86
2007 Saturn Aura - hey it WAS a GM product |
