Old 08-17-2005, 07:59 PM   #1
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Blazer Door
Looking for an '72 original (OE) passenger side door. Perferably rust free and NO cracks around the hinge area.
Thanks DP
I acid dipped my doors and discovered the top hinge area has a really huge cracked in the sheet metal. I was told that it was not salvagable due to the location and stress on thta area.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 08-18-2005, 08:36 AM   #2
Huck
Huck's Avatar
Understand your problem--I traded for some rust free doors last year only to find stress cracks on the hinge plate area as well. This is a common problem due to lack of lube on trucks/blazers since day one and you can find them on low mileage, rust free, original trucks as well as everything inbetween. You might want to consider some new doors as finding perfect originals is almost impossible. New pop's don't fit quite as well as originals but at least they will have good hinge plate sheetmetal. I've got to find a solution as well --imagine perfect rust free straight doors---with cracked sheet metal at the hinge plates~~~UGH!!!
Huck is offline   Reply With Quote
Old 08-18-2005, 12:14 PM   #3
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Its nothing but pain! The acid dip also reveled the swiss cheese at the bottom of the door. Luckily the drivers side is perfect. The only diference I see in converting trucks doors is the originality of the extra plate that is around the rear striker plate. I haven't taken one of these off to see if could be grafted it onto the truck door for the exact look.
Old 08-18-2005, 03:34 PM   #4
jhow66
jhow66's Avatar
Did just that on a drivers door on Orangeuavol's Blazer. Just drilled out the spot welds and used these holes to weld it back on to a cut down PU door.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 08-20-2005, 07:52 AM   #5
Huck
Huck's Avatar
Every Blazer I've parted or looked at close like-with the original doors and reinforcement plate--had doors that looked like a pickup door cut down. I'm beginning to think that this is what the plant did. That extra plate that surrounds the stirker mech. doesn't do much! Never saw a Blazer with the latch mech. broken out. The real problem is the hinge reinforcement which got nada! But then again I guess an offroad rock crawler might flex enough to create a problem there but I never saw one.
Old 08-20-2005, 12:01 PM   #6
72addict
Could the crack problem be fixed from the inside if the skins were removed?
1957 Cameo
72addict is offline   Reply With Quote
Old 08-20-2005, 12:06 PM   #7
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
V the crack out and weld it back up. Then grind the weld back down smooth. It works great!! Should get you 10 to 15 more years of good service even more if you lube the hinges.... WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 08-22-2005, 04:00 PM   #8
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I've never tried to weld it back together, I was told by two reliable sources that it would not hold because of how thin the sheet metal is in that area. So, if you stripped and fixed the door, it would be a waste of time and money. On the other hand, what do ya gotta lose...
Still looking for a good door though!
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
