urban fourwheelin
blinker help
I have a short in my blinkers, they come on when I step on the brakes. what should I start to look at? Anyone have this problem before? I have new engine harness and front light harness. could it be the sockets? they look like crap. thanks for any pointers
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
When did it start doing this? Just started all at once, after I did --.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
urban fourwheelin
just noticed it. It has had a new engine and front harness 4 months ago. I didn't notice a problem though. I'm sure it could be lot's of things. I haven't done anyting to the wiring besides the new harness. the blinkers work, but when I step on the brake pedal the drivers side running lights come on.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. Last edited by RED72blazer; 08-18-2005 at 12:30 AM. |
Sounds like it is in your turn signal switch. If you have another switch just plug it in to the connector and check to see if it still does it. If not you have found your problem. Also check to see if all the wire colors match on both sides of the connector to the turn signal switch. A wire plugged in wrong will cause this problem.
