Old 08-18-2005, 01:20 AM   #1
steve k.
transmission cooler and pan recomendations?
To increase the cooling for my transmission i want to go to a larger pan. Is there any recomendation on the brand. i've looked through catalogs and all cast alluminum pans look the same with prices ranging from $90 for Summit pan to $130 for Hughes. What's the difference? Both are finned and both hold 2 extra quarts.
I also need recomendation on the transmission cooler.
The truck is a 1981 C30 used for towing a race car. Total weight of car and trailer is about 3500lb.
thanks for your advice.
steve k.
steve k. is offline   Reply With Quote
Old 08-18-2005, 05:40 AM   #2
Mike76251
I don't like deeper pans cause they hang down too low.
I also don't like Aluminum pans because they are not as strong as a steel pan should that rock fly up and hit them.
As far as a cooler.......get B&M's largest (28,000gvw...I think).
The cooler and it's lines will give you more fluid in the system so you might not need a deeper pan anyway.
I mounted my B&M cooler in front of my AC condensor with flat steel bar. I don't trust plastic tie thingys.
I also used 1/2" stainless for the lines. All the rubber hoses I have tried leaked soon after installation.
Mike76251 is offline   Reply With Quote
Old 08-18-2005, 08:31 AM   #3
1987 Shortwide
I'll have to check what brand aluminum pan I've got on mine... I'm really happy with it. I went down to my tranny shop and had them get me the most heavy duty cooler they carry. It came with female A/N ends, which worked perfectly because my trans lines are steel braided with A/N fittings on both ends. No leaks and a great look, not to mention very hassle free.
~Steve~
Friesen High Performance Auto and Graphics
Toy: 87 Shortwide, 406 smallblock with a little boost
My 87 buildup
Daily Driver: 99 Sierra SLE 4X4. Black on Black and harder than hell to keep clean.
1987 Shortwide is offline   Reply With Quote
Old 08-19-2005, 10:16 AM   #4
daveM
daveM's Avatar
i just put a Mr Transmission cooler on my '87 TH400 trani. The big cooler out of the 3 listed on the box. I also pull a 3500 lb trailer.
No problem. Maybe runs at 190 when pulling the trailer.
No trailer, -had a problem. Maybe 105, 110 degrees. This was with the trani cooler only. Not connected to the rad.
What I had to do was run the trani oil through the cooler... this from my previous testing brought the fluid down to around 100 degrees. I then took it from the cooler to the Rad Cooler which then heats the fluid up a bit.
Trani now runs around 130 - 140 degrees. It should be a bit warmer but perhaps I have too large a cooler when not towing the trailer. Anyway 130 is better than 100.
Dave
'87 Chevy Pickup (Nice)
'75 CB750K Four Honda (beautiful)
Quiet (stock exhaust)
Till you get on it then she...
Sounds Like a Porsche
daveM is offline   Reply With Quote
Old 08-19-2005, 10:50 AM   #5
79Silv4x4
Workaholic
79Silv4x4's Avatar
I recently bought this but have not yet had the time to install it.
79Silv4x4 is offline   Reply With Quote
