Old 08-18-2005, 02:26 AM   #1
72short
cut coils? how low
how low will my truck drop if i cut 1 coil off the front, and 1 and a half off the front, thank you very much for the answers
72short is offline   Reply With Quote
Old 08-18-2005, 02:44 AM   #2
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
usually 1 coil is 2-3"
Make sure you cut the flat end of spring not the pigtail !
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 08-18-2005, 09:05 AM   #3
72BLAZERDUDE
72BLAZERDUDE's Avatar
Only cut 1 full coil off of your front springs and only off the bottom. Any more causes a number of problems. Anything other than full coils then the springs will not sit right in the spring pocket in your lower a-arms. Springs start to get to short and can fall out of the pocket if the truck is jacked up anywhere in the front except under the a-arm. As you cut coils off of the springs it loses its ability to support weight. If you go more than 1 coil you will have to change your mounting studs to longer ones on your upper a-arm shaft because you wont be able to get enough shims behind it to get it aligned with the stock studs.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 08-18-2005, 02:34 PM   #4
Col Clank
what is the best way to cut the coils....
Col Clank is offline   Reply With Quote
Old 08-18-2005, 03:45 PM   #5
terrym1
terrym1's Avatar
mini grinder with cut off wheel just my .02
terry
terrym1 is offline   Reply With Quote
Old 08-18-2005, 03:54 PM   #6
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
You may want to look at pricing on drop coils from McGaughy's or ECE. I know McGaughy's makes quality suspension components. I have them on both my trucks. They are usually $109- for a pair. Worth the investment IMO. Especially for the safety alone. Your suspension is a vital part of your truck and not an area you want to skimp out on. Just my .02 though.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
