08-18-2005, 04:34 PM | #1 |
Tot Roddin'
X Pipe Exhaust
Does anyone have picture on how they ran their x pipe in their exhaust? I'm wanting to add this to my exhaust, but with planning on lowering the truck 3.5/5 or 4/6, I'm not so sure I'll be able to accomodate this option. Any feedback will be greatly appreciated. Thanks again guys!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
08-18-2005, 05:21 PM | #2 |
Here are some pictures of how I did my x pipe.
08-18-2005, 09:15 PM | #3 | |||
Union Electrician
That is sweet!!!
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
08-18-2005, 09:42 PM | #4 |
An American Soldier
Man, that does look sweet!! Does the entire X unbolt for when you need to get to the transmission?
Dan dan.brue@us.army.mil |
08-18-2005, 10:59 PM | #5 | |
08-19-2005, 12:46 AM | #6 |
I am assuming the silver box is the gas tank. What is the black thing behind it?
69 C10 LWB 350CI "3 on the tree" |
08-19-2005, 01:09 AM | #7 |
Seasonal Poster
I think the silver box is the tranny pan and the black one is the oil pan...you have your orientation backwards I think Gas tank is the red one way off in the distance.
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW |
08-19-2005, 01:39 AM | #8 |
Professional Grade
That X-pipe is sweet!
Where did you get that? Or did you build it yourself?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
08-19-2005, 07:53 AM | #9 |
Tot Roddin'
I notice that you have a Y pipe and the end of your headers, where does the other pipe go to?...........Or..........now that I look at the pictures again, what is that extra pipe coming into the X-Pipe? Or am I just seeing things?
08-19-2005, 08:27 AM | #10 | |
08-19-2005, 08:30 AM | #11 | |
08-19-2005, 09:16 AM | #12 |
Lovin' Life in Miss.!
He is forgetting perspective of truck. Sees header pipes coming to collector and thinks it's a y exiting to rear.
08-19-2005, 09:25 AM | #13 |
Vintage Evil
What are the benefits of the X pipe. I have seen them advertised all over the place but have not actually heard anybody say anything about them.
Current Rides: Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread EvilK5 - 71 K5 Blazer Evil Twin - 2006 Suzuki M109R EvilDmax- 2018 GMC 2500 Denali Duramax |
08-19-2005, 12:22 PM | #14 |
Professional Grade
They smooth out the idle on the truck by taking advantage of the scavening effect and balance the pressure differences between the two pipes. They have been proven to improve torque numbers, and have a significant affect on removing that irritating "droning" noise from your exhaust. Makes it sound a bit more like a high powered European V8 car on sterioids
08-19-2005, 04:29 PM | #15 | |
08-19-2005, 04:48 PM | #16 |
3" $99.95
http://store.summitracing.com/defaul...=egnsearch.asp 2.5" $89.95 http://store.summitracing.com/defaul...=egnsearch.asp Kits come with eight clamps. I would like to know the size of the shared opening. Who makes mandrel bent tubing that is formed to go over the rearend? If we can find those pieces we could list an exhaust kit in the FAQ.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
08-19-2005, 11:14 PM | #17 |
Professional Grade
Man, that is very slick! I think I am gonna have to build mine in a similar fashion!
I need to hack my exhaust up to make it fit around the transfercase anyways. I'll have the x between my tranny and t-case, should be right behind the headers that way (I am running a divorced case, so the x would be right under the driveshaft between the two) I'd probally make my own though, looks like two peices of tubing that are bent 90 degrees, welded together in a way to make the center pass through the largest possible, then flared on all the ends. I like the idea of the clamps on the ends too, pipes that go from the headers all the way out the rear wheels are way too long to easily pull out from under the truck if needed be...
08-19-2005, 11:34 PM | #18 |
383stroker.
What headers are those if you don't mind me asking? JYD |
08-20-2005, 10:29 AM | #19 | |
08-20-2005, 12:03 PM | #20 | |
Kinda figured they were hookers and were made for somthing else. I'm in Brunswick. Jim |
08-20-2005, 12:48 PM | #21 | |
08-20-2005, 01:13 PM | #22 |
383,
Nice looking truck don't think I have seen it over here,I would remember it if I had.I have a 72 in progress It's med green.A lot of people from Jesup, Brantly etc.work over here 341 is a real hoot in the morning huh! Maybe when the heat index gets below 100 I can get some more done to mine.Someday when you are in town maybe we can chew the fat. Jim |
08-20-2005, 01:43 PM | #23 | |
08-20-2005, 01:55 PM | #24 |
I don't have a cam right now it's one of those things on my "list" Did't know about the cruise I'll try to make it soon.
Jim |
