Heater core. What a PITA
My last project was to replace my heater core. It had corroded, and while working on my engine
I barely touched the hose thing, and it bent and started to leak. I got a new core at a local shop for like $30 and took out my trusty manual to do the repair. I read the thing and thought, nah, that cant be right. Can it? Do you really have to remove the wheel well? And the hinge to fender bolts? Yep. What a PITA. As usual, I went a little camera happy while I was at it.... I started by taking out a few bolts on the wheel well, I didnt really need to take it all the way out to reach the heater housing. Once I got the bolts off the firewall side it would have pushed down enough, but I figured while I was at it I could seal the whole thing with rust stuff. Look at the pile of rust that dropped when I undid the 3 bolts to the clip! Getting the heater case off the firewall requires the hood hindge to be slid back a few inches. This was fun. I propped up the hood with some 2x4 and unbolted the hindge, slid it out of the way and quickly took out the heater unit so I could put the hindge bolts back in finger tight. I didnt want a good wind to come up and close the hood on my head or something else important. Now on to my next issue. The stupid little bracket that holds the core in place did not fit the new unit. The after market core is a little thicker. It was a real bugger to get on, and then in stuck out at an odd angle. After a few head scratches I decided to loop a cable tie through the hole and arround the pipe to secure the front of the unit. Then in the back I was able to screw it in place. I know its plastic, but it didnt melt and actually looks pretty good. Here is my wheel well when I took it out. Then I cleaned it up real good, scrapped off all the surface rust and painted it with some good 'ol rust paint. Made sure to hit those rust spots real good. All done! What I thought was going to be a 30 min project ended up taking me almost all morning. Now I need to clean up my other wheel well so they match. ![]()
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
![]() ![]() Join Date: Jan 2005
Nice job!
Nice job. Did the rust scale come from under the battery tray? If so, that might be your next Remove, Clean, Paint, Install project. From what I have heard and read the lower front of the passenger fender will rust from the inside because of the battery acid. A baking soda solution bath can tell the tale.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
#4 | |
They say the first part of the vehicle to go down the assembly line is the heater core.... they build the rest of the car around it.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
Where's my beer?
If you think the truck is bad, (it's damn easy) try doing one on my Z28. I've done my trucks core, and I loved the fact that I stood INSIDE the engine compartment. You
V8 guys may not be able to do that, one more reason for 6 in a row!
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
Questionable
That's really the only place with any real rust on my truck that i've found - battery tray. I need to replace mine. If I could find one for around $25 that's prepped with something to keep it from rusting, I'd do it in a heartbeat.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
While working my way through college I spent almost two years working at a car repair garage. I had one guy come in and put 4 new tires on a 76ish Impala for around $200. (Late 1980's dollars).
A few weeks later he comes in saying he smells anti-freeze. We quoted another $200+ parts and labor to put in a new heater core. HE JUNKED THE CAR! Now as a struggling college student that didn't make sense to me but what are you going to do? Spend $200 for a heater core in a $200 car? To make a long story short, back then GM did start with the heater core and built most of their stuff around it.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Scary, I would have just disabled the heater core (looped the hose) before junkingit.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree Last edited by farside847; 08-18-2005 at 11:26 PM. |
#10 | |
far..., its Minnesota, Land of 10,000 Frozen Lakes
![]() Quote:
#11 | |
I just sold a 95 Z28 but I do have a one owner 93 S10 and yes I have replaced the heater core. To do it simply you need to remove the radio and loosen the passenger side of the dash along with a multitude of other things. I am not sure if I would replace the next one.
#12 | |
No heater = no see out the windshield.
#13 |
Captain Ed
Our trucks have one of the easier heater cores to replace. Some cars have to have very nearly the entire dash removed.
Easiest one I ever saw was on a 72 Galaxie. Had a metal plate with six screws on top of the eterior of the heater box. The water ports stuck up through the plate. Remove the hoses and the 6 screw and pulled the heater right out. Whole job took me 20 minutes. I ain't much of a Ferd guy, but that was one place they had a better idea.
If you ain't bleedin', you ain't workin'! 1999 C3500 LS 7.4L |
#14 |
![]() Join Date: Aug 2001
F&%d is not any better. I had a 80 Crown Victoria in college. heater core went and i could not afford to fix since you have to remove most of the dash to replace. i remember it being like 400-500 in 1991. i looped the heater hoses and drove it 3 more years. kept lots of blankets and gloves in the car LOL!
#15 | |
Captain Ed
#16 |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Those aftermarket heater cores that you get from most parts houses are the cheap non fitting "Made in Mexico" heater cores. I have complained to many parts stores profusely to try to get them to talk to the manufacturer, to get them to fix the tooling. Hasn't done any good yet!! This is why I sell the USA made ones. They are a little more expencive, but they fit and even are a little heavier. I would have pulled it out and took it back to the parts house that sold it to you. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#17 | |
#18 |
collector of vintage rust
Why do you have to remove the inner fender? I have replaced a 67 and a 71, and didnt have much problem after loosening hood hinge.
#19 | |
#20 |
the proof is in the pudding!
#21 |
![]() Join Date: Jul 2004
1/4 drive swivel sockets. Mans best freind. Works for me on those, never have had to remove and sheet metal. If your arms are long enough and skinny enough you may also get that one SOB in the corner from under through the fender.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
#22 |
I did mine without removing the inner fender too.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#23 |
What about doing it with just the inner fender coming out and not touching the hood??
I have been waiting a year now to go at this because of the time it took to aligne the hood. I wonder if there is a fab. idea out there for a quick access door?
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
#24 | |
#25 |
try one with a/c
