Old 08-18-2005, 07:13 PM   #1
TEAM THC
CUSTOM CHEVY FIEND
TEAM THC's Avatar
Spindle Install
Are Drop Spindles Difficult To Install My Self?
Im Very Mechanicaly Minded But I've Never Changed A Spring
Or Spindle.
TEAM THC is offline   Reply With Quote
Old 08-18-2005, 07:54 PM   #2
C&C Chevy
C&C Chevy's Avatar
You might want to read up on the job first.
http://www.73-87.com/7387garage/chas...n/frontend.htm
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 08-18-2005, 08:00 PM   #3
milehightoyz
AttentionDeficitDisorder
milehightoyz's Avatar
simple job youll have it done in an hour a side. dont forget to grease everything when you get done and pack your bearings while you got them apart. good luck.
milehightoyz is offline   Reply With Quote
Old 08-19-2005, 08:53 AM   #4
beaterC10
The actual install shouldn't be bad, but don't count on a complete bolt in operation. You will likely have to tweak the flexible brake lines and might have to do some grinding on the lower control arm to prevent interference with the wheels.
beaterC10 is offline   Reply With Quote
