I want get some good info on a carb
I have a 454 bored .40 over, Port and Polished, 3" headers and 3" flowmasters, etc. What carb would you put on it if you had to get a new one? As of right now I have a 600 cfm edelbrock or a 1406 edelbrock, no choke. Is that too little as some have told me or is it good enough?
![]() PLease let me know. Mike also with gas prices ![]()
1985 Silverado Club Cab Dually ![]() ![]() |
ureckmefixit2@cox.net
Im not going to tell you what brand. Size should be for what you wont to do with your engine. If you want gas miles stay with what you have. For HP use what the cam company said to use. I would think around 750 or 850cfm and higher if your cam will take it. Matt
That's U RECK ME FIX it 2 74 Chevy Short Bed 355ci Sportsman II 64cc Angle Plug Crower Custom Grind .462in .486ex Dyno Test 422hp @ 5600 And it's got a Holley 3.73 Gears 12 Bolt 3.73 w/Posi 700R4 Going In I'm a Body Man So There! That's why it's not painted |
Right turn Clyde
1406 Edelbrocks run on the lean side for most 350s let alone a 454. 600 Cfm will work but you will need to have to jetted to suit your 454.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
No No
I'll say it
![]() Sell those carbs and get a 750cfm carb.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
square body trucks an addiction or an investment either way they consume all my extra time and money |
i just read your profile i roflmao at myself your a mechanic
750 edelbrock will work nicely.
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction ![]() |
No No
Under certain situations it's avantatious to have a smaller carb but you live in Tulsa Ok, If i'm not mistaken your altitude is right around sea level. Plenty of air to use a 750 on a SB, of course I doubt it would see all 750 CFM of flow. A 750 on the setup you have now will be a tad on the lean side but in a safe jetable range.
If you were to use a 600 CFM Holley theres patches to get around running lean on the fuel side of things durring tip in (initial take off or light acceleration) Bigger acc pump, larger acc cam and gotta love a power valve for every vacuum level. So the Holley would be capable of flowing the fuel needed at the right time to run on a larger engine. Thats why HD GM BB's and fNord 429's, 460's came with 600-625cfm Holleys from the factory. Of course this small carb limited the potential RPM range for better or worse. AFB's can be modified to work in these situations but it's a hassle and it will not come close to working like a holley would under the same circumstances. You will be cruising with all 4 holes cracked open durring most light accelration because the AFB design will not flow the same amount of fuel in the primaries a holley setup to run on a BB will. Either way neither 600cfm carb will move the air needed to spin the BB to it's potential. ![]()
