08-18-2005, 08:27 PM | #1 |
rebuilding door hinges on the truck
Can it be done? Gonna take off the new/old doors I just put on and try to drift the pin out. Has anyone done this? If needed I have a torch to put some heat on the barrels that the bushings and pins fit in. I am concerned about the bolt up to the truck, I don't want to knock them too far out and dam* sure don't want to break a stud. Any help is good, Thanks
1969 C10 Long Step,355,700r4w/lockup, HEI,Weiand,750 Performer,1.6 rockers,Camel Humps,Comp 262Extreme,Hedman,2 1/2"pipes, tele/tilt,SunRoof,ps,Disc pb,ac,Cragar,eaton,Corvette style roll pan, Bowtie louvered tail gate,lowered 2/2. |
08-18-2005, 09:55 PM | #2 |
I just did it on my truck. Very easy. Remove doors from hinges (mark hinge location first) I used a punch smaller than the hinge pin with an air chisel to drive it. Pins come out fairly easily. take out the worn out teflon bushings an drive in the brass bushings. Drive the hinge pins back thru the hinge with the air chisel. Cut the new pins off about 1/8" below the hinge (they are longer than the origional). Bolt the door back on lining up your marks. Adjust if necessary.
Good luck Rick / Ca. |
08-18-2005, 10:10 PM | #3 |
Back in the sticks
I did it too, with a hammer and punch. Took longer than I expected, as they are in there pretty tight. Don't know if the torch would help or not as the teflon would melt. Might help, might hinder. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
08-18-2005, 11:19 PM | #4 |
Hinges
Buy them from your local parts supply or Farm fleet---Tractor supply ect---usually about $3-4--cheapest I saw them from a vendor with shipping was $7-9--very simple job----i did mine on the truck,didnt remove door---1 at a time of course.
08-19-2005, 06:53 AM | #5 |
Its Magically Delicious
doing them without removing the door sounds like a pain .... you should right up a faq on how you did that
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
08-19-2005, 03:52 PM | #6 |
OK let me tell y'all how it went. It was a BITC*. Top hinge, hit it and all it did was mushroom the pin. Took the hinge off from the truck, put some heat on it after grinding off the mushroom put it in a vice and it drifted out fairly easy. So I thought that the secret was the heat. The bottom hinge I left on the truck, put some heat to it and tried to drift, but since I did not have good clearance to get a good swing, swinging up not down, it laughed at me. So I think no problem I will just take it off the truck like the top hinge and get a good down stroke. First and second bolt came out fine but I noticed on the third that the nut backing plate was moving and if I had taken out the third bolt it would have dropped away inside and NO way to get at it. So bolted it back up and lots of heat and new words that I didn't no I could say it finally came out. Then the line up of the door, but that is another chapter that you will have to write cause every door is a little different. Was it worth it, of course. Was it easy, NO.
