Trying to remove dash pad.
I give. How does this thing come off anyway. I got a philips screwdriver out and poked it into the holes in the face of the pad and there are no fasteners in there. (removed/and or lost by prior owner?) I can lift the face straight up slightly, but it seems that there are maybe some other fasteners holding it down???
I didn't crawl under the dash to look and I went after the more obvious glovebox door and such. I would imagine it must be something fairly simple, I thought I would ask before braking something ![]() |
An American Soldier
![]() Join Date: Feb 2005
Wolfthing,
There are seven (7) bolts molded into the pad that stick through the metal dash. They have 5/16 or 3/8 nuts on them. You have to get under the dash...they are behind the gauge bezel, above the radio opening, and behind the glove box lining. Hope that helps.
Dan dan.brue@us.army.mil |
![]() Join Date: Jul 2004
You have to remove the glove box and you might as well pull the gauge cluster and and drop the heater contols and radio, I don't think you can get at the little stud bolts otherwise.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
You can reach them, but its a *****. There were only 5 on mine.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
Too many projects
Jim ![]() ![]() '55 Chevrolet Pickup '56 Chevrolet Belair '04 Chevrolet Astro '95 Chevrolet Blazer |
No wonder!!!! Thanks, all of you.
There is also one in each corner that has a funny angle on it. Always the hardest for me to get undone and especially to get started when putting back on.
Good luck - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
67 is sold
They are in there good for sure.
I'm strongly considering leaving mine off and filling the holes ![]() |
