Old 08-19-2005, 12:40 AM   #1
raptorgta
2.5" or 3" exhaust on 72 Blazer
I'm trying to find out what would be my best option for an exhaust on my 72 4x4 blazer. Right now it has a 4" lift but I'm planning on putting an 8" on in the future. My question is can you run a 3" exhaust under it without hurting ground clearance? Or would I just be better off running a 2.5". Thanks
raptorgta is offline   Reply With Quote
Old 08-19-2005, 04:03 AM   #2
k-20
i dont think 1/2'' is going to cxause you any trouble.
k-20 is offline   Reply With Quote
Old 08-19-2005, 07:41 AM   #3
Mike C
Mike C's Avatar
Unless you are going for 500+ horsepower, the 2 1/2" will be easier to run and MUCH easier on your wallet.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-19-2005, 07:31 PM   #4
raptorgta
Thanks for the replys. I don't think I'm anywhere close to 500 HP. I think I will go with the 2.5" I am also thinking about using the dynomax bullet mufflers. I know they will be loud but I only drive the blazer a few times a month.
Old 08-19-2005, 10:45 PM   #5
Mike C
Mike C's Avatar
I have the Dynomax Hemi Turbos on my JImmy. They are NOT loud and still make good power, call me old, but powerful, high-flow AND quiet is where it's at. Ands at $40 each, affordable.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 08-20-2005, 01:51 AM   #6
Russell
Professional Grade
Russell's Avatar
I have 2.5" on my truck, and they are a bit too big in my opinion. I put 2.25" on my 74, and she sounded real good. The 2.5" just sounds a bit too airy, while the 2.25 had a real crisp bark. Very nice
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 08-20-2005, 06:58 AM   #7
see ten
WTB this ad
see ten's Avatar
I have 2.5" to the muffler and 3" from the muffler on back. It sounds pretty aggressive I think. I had already tried 2.5" tailpipes and the turndowns before I settled with this.
see ten is offline   Reply With Quote
Old 08-20-2005, 12:15 PM   #8
raptorgta
That is a nice truck. I hope my Blazer will look that nice when I'm done with it. Thanks for all the replys. I kind of like the idea of going 3" after the mufflers.
Old 08-21-2005, 09:18 AM   #9
Mike C
Mike C's Avatar
If you are going to do 3", no gain behind the mufflers. The gases cool as they go front to rear and take up less volume past the mufflers. 3" in and 2.5" out is probably the best power/noise trade off. And usuallay fewer bends from motor to mufflers than mufflers out the back. BUT it depends on a ton of other things like total exhaust length, total air flow (horsepower), driving style, cam design, etc.
See Ten has it right, though. You should turn the pipes and run out the side. A REAL 4x4 never has big giant chrome baloneys sticking straight out the back. When you have to rock forward and backwards to get out of a big stick you end up packing the exhaust with water and mud!
44 Willys MB
52 M38A1
64 Corvette Coupe
