Old 08-19-2005, 07:45 AM   #1
lowrider79
Headliner Glue
What is the best glue you can use to install a headliner?
lowrider79 is offline   Reply With Quote
Old 08-19-2005, 12:23 PM   #2
Mudder
Mudder's Avatar
I just used 3M double sided tape. Just make sure the surfaces are really clean if ya do.
Mudder is offline   Reply With Quote
Old 08-19-2005, 01:03 PM   #3
70c10
67-72 Addict!
70c10's Avatar
I use GE brand pure silicone in a caulk gun. I use the whole tube on the backside of the headliner keeping it away from the edges and applying it long ways. It withstands extreme temps and can be removed later if you decide to repaint the interior. I use a set of spare metal door panels wedged between the seat and ceiling to hold it up there (perfect length) . Just be sure to fold a towel over both ends of the door panels to prevent impressions in your headliner and seat. Press the headliner in various places to make sure it is tight. At this point you can start applying the trim which will help to hold it up as the silicone cures overnight.I have been doing this method for the last 5 years on trucks with no problems whatsoever!. I hope these directions help. Here is a pic showing the door panel trick!. Some people build a brace with plywood and 2x4's but my way is easier and faster if you have spares laying around . Good luck.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-19-2005, 01:50 PM   #4
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
gorillia snot (napa ) or pep boys
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-19-2005, 05:28 PM   #5
Blazer1970
Blazer1970's Avatar
GTA - General Trim Adhesive
Blazer1970 is offline   Reply With Quote
