Dupli-color spray bed liner, anyone use it?
Like the sign says. By box ( if it has a floor & 4 sides it's a box-- It's a Canadian thing ) so, my box looks pretty ratty and it's drivin me nuts. I was thinkin of just painting it but saw the Dupli-Color stuff and wonderd if it was any good? how many cans to do the inside of a long box? ( there's that word again ) how it looks and how permenant it is. If I just paint it later I could do a decent job.
I got a bench seat baby, you don't have to sit over there. |
Captain Ed
I used it. Took 3-4 cans for a short stepside. The trick is to spray it from 2+ feet away. Mask well, shooting from that distance creates quite a wide pattern and make a lot of overspray. It shoots very heavy and if you try to shoot closer it will sag/run.
If you ain't bleedin', you ain't workin'! 1999 C3500 LS 7.4L |
my gas saver
i've never used it myself, but one of my buddies has tried it another tried the herculiner. the dupli-color looked like crap and peeled all over. the herculiner actually came out pretty good. that might all be in the application of the two. i hear if you don't get it scuffed up really good that it won't last at all.
there was a guy on the board that tried the eastwood stuff awhile back and it looked killer. oh, do ya have a cap on that box eh? ![]()
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
67 is sold
IMO when it comes to spray bedliners, nothing beats the pros if you actually use your truck bed.
I have a Rhino liner in my GMC ![]() |
![]() Join Date: Aug 2001
![]() (IT STINKS TO HIGH HEAVEN FOR WEEKS)
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 08-19-2005 at 11:01 AM. |
#6 | |
Happy to be here
![]() Join Date: Mar 2000
'69 Step
Can you spray liner over a wood bed??
#8 | |
User #12137
![]() Join Date: Apr 2004
Too many projects
I've sprayed it into beds before. As far as the sticking, it all depends on the prep. There are others on the market that are better. But for a cheap liner, it's OK. I had a little left, and sprayed the floor of my truck.
As far as it sticking to wood, I've never done that, but again, depending on the prep work, there shouldn't be a problem with it sticking.
Jim ![]() ![]() '55 Chevrolet Pickup '56 Chevrolet Belair '04 Chevrolet Astro '95 Chevrolet Blazer |
I've sprayed a few with herculiner. I've had trouble with it peelling later. I think its a moisture/temp problem. The stuff I've sprayed in the evening liked to peel in the low spots. I didnt feel any dew on the surface but I think that is what was happening. Even so 2 gallons in a short bed makes a very thin coat. I dont think I'd use the stuff again.
67-72 Addict!
This is a pic of Bondo brand Tough Gaurd I recently did on my 71'. I taped a laser straight line around the perimeter of the bed and it turned out awesome for a roll-on job. Nice even texture and I've gotten a ton of compliments on it and it's really heavy duty too.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
![]() Join Date: Dec 2004
i used the herculiner once,but apparently i didn't prep well,it started to peel up,but my uncle sprays in rhino liners and i learned that you need to get a lot of good scuffs or scratches in the paint to get it to stick
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
#13 |
fugedaboutit
![]() Join Date: Mar 2005
IMO the Duplicolor truck bed liner sucks. I sprayed some as instructed and it looks like cheap flat black house paint.. hardly any texture. I am looking into some traction paint used on car haulers. Its cheap and looks tough.
Currently truckless ![]() |
#14 | |
fugedaboutit
#15 |
hurculiner works best.....prep as recommended.....has more rubber in it...
than any other brand....... use kitchen floor wax..... for max shine......be there done that..... Last edited by rage'nrat638; 07-12-2007 at 07:04 AM. |
