Biggggg Problem!!
I have an 89 blazer and was tearing the carpet out to weld some sheet metal on the floor due to holes being in it. I then discovered that the frame was rotted as well and that i would have nothing to weld the patches to. Is there anyway to save my truck???? Please post any suggestions that you may have i would appreciate it alot!! Thanks!!
can you get some pics of what you are talking about?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
Outlandish Trends - FL
wow, that sucks. Maybe find a donor truck you can use the frame off of? As long as the cab/truck is salvageable, you can find another frame in good shape to use. DMV goes by the VIN on the cab.
-Bret 67 short-fleet sold! |
If you need a frame, I'll have one available in a month maybe less. I don't know where you are so I don't know if it is feasible for you.
![]() Join Date: Apr 2004
Are you talking about the floor braces? The body is not welded to the frame.
Last edited by hotrodhomi; 08-22-2005 at 04:04 PM. Reason: Because I wanted to...Dang |
![]() Join Date: Aug 2005
Yeah, the cab supports can be replaced if that's what your talking about.
