user # 2756
![]() Join Date: Jun 2001
I replaced my oilpan gasket today w/ a one piece gasket and the damn thing still leaks
![]() The one piece seal had instructions that said to install dry w/o adhesives. So I did, the thing leaks where the oil pan/timing chain cover meet. I think I'm going to pull it again and use some silicon. What do you guys think? I did get my transfer case and rearend leaks fixed though ![]()
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
I believe in small quantities of silicone where the pain meets the block and t-chain cover. Also, make sure your front balancer seal is not the source! Having an old truck that doesn't leak is a joy.
Professional Grade
My mistake there was that I forgot to pull the old front timing chain seal out! Also made it extremely tough to install, lol
After I pulled that thing out, I re-installed with a dab of silicone in each of the four corners, and not a drip of engine oil since! ATF on the otherhand has been dribbling out of my tranny for a while now, lol
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
user # 2756
I re-did it today with some silicone and the leak is stopped. What a pain in the butt.
