Old 08-21-2005, 01:47 PM   #1
rchdrm
The start of the $ pit!
rchdrm's Avatar
Rear tank and roll pan safety concern
My son and I are thinking about putting a roll pan on his 68 as well as moving the gas tank to the rear of the truck.
I have a safety concern over a rear end collision. Has anyone addressed this on their truck? Did you add extra support to the frame?
Thanks for any feedback!
rchdrm is offline   Reply With Quote
Old 08-21-2005, 02:19 PM   #2
Joe67
67 is sold
I moved my tank and plan to run a rear roll pan.
Per a recommendation on this fine board, I went with the rear brace from Early Classic and had it powdercoated black to match my chassis
http://www.earlyclassic.com/
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 08-21-2005, 04:31 PM   #3
rchdrm
rchdrm's Avatar
where did you get the tank?
Where did you get the tank? Looks great on the frame.
Old 08-21-2005, 04:48 PM   #4
Joe67
67 is sold
It was fabricated by member fuelcellguy (Mark Fowler).
Checkout out this thread for more info
Old 08-21-2005, 05:04 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If you are concerned about this kind of accident, you should do some sort of belly pan or skid shield too. Most of the time a car will go right under the back of a truck and lift the rear up. That would slice a tank up instantly.
Old 08-21-2005, 05:55 PM   #6
cdowns
cdowns's Avatar
with a kid i'd be more worried about a flat tire than gas tank exploding
Old 08-21-2005, 09:22 PM   #7
blazer1971
On my blazer I have I beams welded between the frame rails right behind the front and rear roll pan.
blazer1971 is offline   Reply With Quote
Old 08-21-2005, 09:43 PM   #8
Longhorn Man
a spare tire is no problem...toss it in the bed, or carry a tripple a card.
Exploding over some one's hood is a bit harder to recover from...and the following law suit is pretty hard to recover from too. (need to make sure it is up to DOT standards set forth in 68)
