Old 08-21-2005, 03:45 PM   #1
TireSmoke420
One of the few GMC'ers
TireSmoke420's Avatar
Torque converter/flexplate?? help
yesterday i got the t/c put into the tranny i know i got the notches lined up and all cause it went the whole ways in and the fins on it almost rub the tranny. when i bolted tranny back to motor there is a gap big enough to fit my finger through btween t/c and flex plate. now qwestion is. can i just pull t/c out a lil till it hits flex plate or have i screwed sumthing up. really dont wanna bust sumthing in the t/c when i go to drive it casue parts store will only take it back if i havnt put tranny fluid to it. im confused wit this please help
87' Silverado 4x4
"Young, Dumb And Full Of Cum"
TireSmoke420 is offline   Reply With Quote
Old 08-21-2005, 04:27 PM   #2
OLDROCK&ROLLER
OLDROCK&ROLLER's Avatar
The space you are referring to is normal. Just slide the t/c to the flex plate and bolt her down.
72 CHEYENNE 10 SUPER
468/400/3.73
OLDROCK&ROLLER is offline   Reply With Quote
Old 08-21-2005, 04:49 PM   #3
TireSmoke420
ok thnks just wanted to make sure i wasnt going to slide it out and bolt it down. then start driveing and bust sumthing. dont know much about trannies but i can sure make a truck look good. lol
87' Silverado 4x4
Old 08-21-2005, 10:00 PM   #4
rage'nrat638
rage'nrat638's Avatar
what he said......use the correct bolts.......your set.....
rage'nrat638 is offline   Reply With Quote
Old 08-21-2005, 10:26 PM   #5
70 net440
Junior Member
70 net440's Avatar
Depending how big your fingers are you may have too much clearance. You can shim up the gap with washers, but you should use a caliper to make sure they are flat and the same thickness. If the clearance is less than 1/4" you should be fine.
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
70 net440 is offline   Reply With Quote
Old 08-21-2005, 11:45 PM   #6
krue
Designated A-hole!
krue's Avatar
Sounds normal to me. Bolt it up good and tight.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 08-25-2005, 01:04 AM   #7
TireSmoke420
got everything put back together today. runs and goes awesome
87' Silverado 4x4
